Fix song matching without losing ratings
Server Version#: 1.26.0.5715
I have discovered that some of my music was not named correctly, resulting in incorrect matching.
But I have already spent time rating the music.
The only way I can see to fix this is to use the Plex dance. But this will lose the ratings that I’ve already done.
There needs to be a way to specify “include track re-matching” when fixing a match.
Note that I think it’s actually a serious problem that the Plex dance is styled as “The Plex Dance TM”, because that suggests this workaround is permanent - when it shouldn’t be. Because it is a workaround - and is just not always suitable.
Actually, the issue seems to be more basic:
  • It’s just ignoring some track numbers.
I have tried to fix a match of an album, because it had misidentified some track numbers, despite the filenames being correct.
In the search, it showed correctly - with the correct tracks in bold and the actual missing ones faded. But when I select it, it didn’t change any of the tracks.
