Server Version#: v1.18.2.2029-36236cc4c - Synology DS218j armv7l
Player Version#: PlexWeb 4.12.2
After update from v1.18.2.2019 Media Server is not reachable from PlexWeb or LG Plex application.
Relevant/suspicious logs with my email fields replaced
Nov 15, 2019 18:44:46.013 [0x72223450] DEBUG - HTTP requesting GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Nov 15, 2019 18:44:46.078 [0x704d7450] ERROR - Error issuing curl_easy_perform(handle): 28
Nov 15, 2019 18:44:46.078 [0x704d7450] DEBUG - HTTP simulating 408 after curl timeout
Nov 15, 2019 18:44:49.675 [0x704d7450] DEBUG - MyPlex: Last published value didn't change, we're done.
Nov 15, 2019 18:44:49.921 [0x7137d450] DEBUG - HTTP 200 response from GET https://plex.tv/media/providers?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Nov 15, 2019 18:44:49.990 [0x72223450] DEBUG - HTTP 200 response from GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Nov 15, 2019 18:44:49.994 [0x7344e450] DEBUG - HTTP requesting GET https://plex.tv/api/v2/server/webhooks?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Nov 15, 2019 18:44:51.008 [0x72223450] DEBUG - MyPlex: Last published value didn't change, we're done.
Nov 15, 2019 18:44:51.060 [0x6d511450] DEBUG - MyPlex: Sending Server Info to myPlex (user=<email>@example.com, ip=, port=25152)
Nov 15, 2019 18:44:51.061 [0x6d511450] DEBUG - HTTP requesting POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx&async=1&asyncIdentifier=417dda34-ca2d-434f-a81e-ca6e7ef7fab5
Nov 15, 2019 18:44:51.132 [0x72223450] DEBUG - CERT: Certificate will not expire soon.
Nov 15, 2019 18:45:06.028 [0x7344e450] ERROR - Error issuing curl_easy_perform(handle): 28
Nov 15, 2019 18:45:06.398 [0x7344e450] DEBUG - HTTP simulating 408 after curl timeout
Nov 15, 2019 18:45:06.583 [0x6d511450] ERROR - Error issuing curl_easy_perform(handle): 28
Nov 15, 2019 18:45:06.583 [0x6d511450] DEBUG - HTTP simulating 408 after curl timeout
Nov 15, 2019 18:45:06.972 [0x6d511450] DEBUG - MyPlex: Published Mapping State response was 408
Nov 15, 2019 18:45:06.972 [0x6d511450] WARN - MyPlex: Invalid response when mapping state (code=408):
Nov 15, 2019 18:47:44.286 [0x6edff450] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.movieposterdb], we're killing it.
Nov 15, 2019 18:47:44.358 [0x6edff450] DEBUG - Stopping [com.plexapp.agents.movieposterdb].
Nov 15, 2019 18:47:44.358 [0x6edff450] DEBUG - [com.plexapp.agents.movieposterdb] Killing.
Nov 15, 2019 18:47:44.286 [0x6eb11450] ERROR - Timeout or error reading status line from plug-in pipe [com.plexapp.agents.lyricfind], we're killing it.
Nov 15, 2019 18:47:44.359 [0x6eb11450] DEBUG - Stopping [com.plexapp.agents.lyricfind].
Nov 15, 2019 18:47:44.359 [0x6eb11450] DEBUG - [com.plexapp.agents.lyricfind] Killing.
Nov 15, 2019 18:47:44.416 [0x6edff450] ERROR - Error received reading configuration for com.plexapp.agents.movieposterdb
Nov 15, 2019 18:47:44.416 [0x6edff450] DEBUG - Stopping [com.plexapp.agents.movieposterdb].
Nov 15, 2019 18:47:44.416 [0x6eb11450] ERROR - Error received reading configuration for com.plexapp.agents.lyricfind
Nov 15, 2019 18:47:44.416 [0x6eb11450] DEBUG - Stopping [com.plexapp.agents.lyricfind].
ps. is there a way to downgrade on Synology without loosing metadata/settings?
