Flawless for Years - Now Intermittent Buffering on Files I've Played Before
Server Version#: 1.27.0.5897
Player Version#: Shield Pro 2019 9.4.0.33208
For the past few weeks, maybe 2-3, the vast majority of my files have now starting buffering during playback. This is completely new for me as I’ve had zero issues playing anything for years. I have private remote server and my house bandwidth is 1GB. In the past, routinely playing 4K HDR Remuxes have been no issue.
But now, seemingly standard HD files buffer randomly and intermittently - meaning at no particular time during playback and the same file can play black flawlessly at other points throughout the day. These are all files I’ve played numerous times before (the comfort shows).
I’ve been unable to find a common variable - TrueHD, DTS, bitrate, etc. Nothing seems to be consistent. Seemingly, the SD shows play fine; but I do not believe this is a bandwidth issue as direct speedtests to the server are high and consistent. Additionally, other users outside of my home report no issues.
My players in house are 2x Shield Pro 2019, 1x Shield Pro 2017 all direct play. Watching Plex server console shows no errors during buffering. I have no idea where to look for errors at this point.
Any thoughts are appreciated to help me track this down.
Logs attached.
Plex Media Server Logs_2022-06-16_20-44-24.zip (5.9 MB)
Out of curiosity, how far away is your remote server, and is your ISP Frontier?
My ISP is Verizon FIOS. My server is in an OVH datacneter in BHS. I’m in NY.
Ah OK. Looks like we have a very similar setup, with my server also being hosted by OVH in BHS, although I’m in Los Angeles. Frontier’s peering has been absolutely terrible for the past couple of months, which in my case results in severe buffering when watching anything 4K/high bit rate. Sometimes it’s so bad that I can’t even watch much smaller files.
I run tracert every once in a while to see if anything has changed, but it’s mostly all over the place. Not saying this is your issue, but probably worth looking into.
Curious what kind of ping you get from NY to BHS. LA to BHS is usually in the low to mid 80s.
My friends in LA have no issue with playback to my server. My trace and pings are all in the very acceptable range 20ms and under.
And what is your location and ISP?
I have lots of LA users on different ISPs, and the only one with issues is me with Frontier sigh. I’ve been running this exact setup since early 2017, and it’s been great for the most part.
The only thing I’ve found that shows up as different on server side is the bandwidth. Normally, this should be complete up and down continuously. I can see on buffering files the bandwidth hover always ‘up’, never coming down to zero.
This shows two separate files (from the same series, season) that buffer on immediate play. When this show (or others) don’t represent this in bandwidth, it plays fine.
This is so frustrating and confusing.
This is a normal bandwidth pattern for a non-buffering show. This is even at a higher bitrate, so clearly not a bandwidth, peering, or network issue. PMS is treating certain files different and serving them different.
And this is the previously buffering file now playing fine.
I’m so sorry. For some reason I thought I was replying to another user. Thanks for the info.
Yes, it is frustrating. So far, I’ve been blaming my issues solely on my ISP, who is notorious for bad peering. You don’t seem to have the same problem, with your pings and trace routes being much, much better. I hope you’ll figure it out.
Does disabling Direct Play help?
It’s very common that allowing Plex to remux the streams into a new container will resolve issues with poorly muxed/interleaved files.
But typically that will appear as REALLY HIGH bandwidth usage, unlike what you’ve shown.
You’re using Google Team Drive right?
I have not yet. I’ll give it a shot, but I doubt this is the issue as I’m seeing it almost every other file I play - I doubt that many files are poor. Also, these are the same files I’ve played without issue numerous times and the same file will work then not within quick succession.
It seems random, or dare I say, temperamental.
Yes, I am. No APi issues reported in console.
I agree, Gdrive is never the issue. If I bypass Plex and play directly from the mount (on my local PC), it always works flawlessly.
Try adding this --vfs-read-ahead=500M to your mount
That assumes he’s using cache-mode full, and even then it won’t help if the bottleneck is somewhere else, which is likely. In my experience, the connection to/from Gdrive is never a problem, unless G is having issues themselves.
Correct assumption. I am not using full cache mode.
I’ve been playing a TV series today sporadically exhibiting the buffering problem. Every time buffering starts the bandwidth monitor shows the same “up only” pattern and buffering will start within a few seconds or so.
I’ve experimented with stopping and then starting the file over again as many times as necessary to get it to stop buffering and exhibit the correct bandwidth profile. So far, it seemingly will ‘catch’ and play without buffering and this will hold for a few hour-long episodes back-to-back until I have to do it again.
Not sure what this answers, but I believe this shows that it’s not a file problem, bandwidth problem, peering issue or Gdrive issue. If it was any of those the problems it would be present every time.
Just to rule out Rclone as the culprit, would you mind posting your mount command? Did you change anything recently?
Do you have the ability to bypass Plex and/or the OVH server for testing purposes?
