Folder with .MKV files showing EMPTY
Server Version#: 1.31.3.6868
On NetGear ReadyNAS_104 with four 4TB drives. 60% full.
Player Version#: 4.100.1
On a dedicated Lenovo PC running Win 10, Microsoft Edge
I have a sub-folder that shows ten .MKV files on Win10 Explorer
The .MKVs DO PLAY using Windows Explorer default Movie & TV player.I
I log-in to my http://127.0.0.1:32400/ and go to the LIBRARIES
I can drill down to that folder and PLEX says “EMPTY”.
This happens on my browser and from my ROKU the PLEX app.
My ROKU-PLEX will find & play other MKV files.
Transcoder quality = Automatic
Transcoder temporary directory [blank]
Transcoder buffer = 60 [default]
Background Transcoder = Very Fast
[unchecked] Disable Transcoding
Maximum simultaneous video transcode = unlimited [default]
I have spent 2 hours + reading FAQ and searching on PLEX community and on Google.
What is wrong?
Thank you for replying.
Jim
Did you already have a look at this support article?
https://support.plex.tv/articles/201543057-why-is-some-of-my-content-not-found/
Thank you for answering.
Yes I saw that one and verified the FileNames are valid.
To make sure I took the first ones and greatly simplified the name [removing the TORRENT name] so it is NAME.S01E01.MKV
Then I went into PLEX and slected Actions: Scan Library Files.
After perhaps 45 seconds [for 532 GB !!] that finished.
I then drilled-down to the folder to get the EMPTY folder message.
I have other .MKV files that play fine.
I can’t figure out the problem.
Do you have any suggestions?
I can give you some screen shots if you like.
Regards, Jim
Plex will ignore files that match the naming schema for tv episodes if they’re added to a movie library and vice versa.
-edited-
At the TOP of the article you linked, it seems to differentiate between a MOVIE folder and a TV folder. Can you help me understand that?
I’m reading Category : Your Media | Plex Support
Gotta pick up the grandkids. Back tomorrow.
Thanks for sticking with me, Jim
Plex is not organizing your media by folders.
Usually you’re organizing your server into libraries where each library is assigned to a specific media type (e.g. movies, tv-shows, music) and associated to one or more “library folders” which contain your actual media.
Plex will then catalogue the content/files from that library folder and pick up various metadata for them. Instead of accessing the files through the folder structure, Plex offers you a number of options to access the media based on that metadata (e.g. titles, actors, directors…) – incl. the underlying folders.
Is it possible that I don’t have some “switch” checked?
All my previous TV shows are fine.
These .MKV files seem to be causing the problem.
Mind sharing the specific naming / organization of those files as well as which exact folder(s) are linked to the library and what type of library we’re talking about? Otherwise this is a rather academic discussion :wink:
Glad to –
As Tom was saying, you can’t mix TV shows and Movies on your file system. When you create a library in Plex you have to pick which one you want
A basic setup
M:/TV ← (point a Plex TV library at this path after you put ALL of your TV shows in that folder)
Ted Lasso/Season 01/Ted Lasso S01E01
Shrinking/Season 01/Shrinking S01E01
M:/Movies ← (point a Plex Movie library at this path after you put ALL your movies in that folder)
The Whale (2022)
Hi JaysPlex7 - thanks for joining-in this thread.
I have had PLEX on this four 4TB ReadyNAS drive for about 15 years.
I have many formats on this one MOVIES [\storage M: ]
For example - we’re watching MASH with no trouble?
How can this work and a newly added TV download won’t?
JayPlex7 - Found a rename that works [or at least TRICK the PLEX server]. ???
I’d like to know if I don’t have some “switch” checked.
 Shrinking.S01E08.WEB.x264-TORRENTGALAXY.mkv
to
SH 1x08.mkv
No, there’s no switch or easy fix for what’s happening here.
Trying to dissect why something works and something else doesn’t isn’t really worth spending time speculating over
When you don’t follow the recommended naming and organizing of your files, some things will work and some things won’t.
As you add more and more media named and organized like this you are going to run into more chances to get things mixed up. Shows and movies intermingling and being combined into duplicates.
The 1x08 is not the correct way to organize tv shows. The s01e01 format is what’s expected and the only thing that will work 100% of the time
You need to reorganize your file structure, libraries and naming. There’s nothing anyone can help you with until you do that
https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/
Could also use pattern match with a .plexmatch file.
https://support.plex.tv/articles/plexmatch/
Maybe try in each season folder…
tvdbid: 70994
pattern: {season}x{episode} - *
Or overall (this can be used for any TV show as long as you follow the same format)…
tvdbid: 70994 (this will need to be adjusted for the relevant show)
pattern: * - Season {season}\{season}x{episode} - *
That’s not going to help while the files are organized in a movie library.
So I need to create a new top-level folder
\storage\TV_Shows as T: drive
Then make T: a new library of the type TVSHOWS
correct?
Correct; except you shouldn’t point libraries to a plain drive letter
I’ve done as you recommended and marked this Reply as the SOLUTION.
All is well now - thanks.
One final question: WHY does it matter that PLEX finds the metadata SINCE I am not utilizing the Meta Data functionality. I have 10+ years of being used to the FOLDER method to view Movies. In my old Folder method and naming work-around I easily found what I wanted to play. The grandkids also know to look in _KidMovies and for example the sub-directory Disney. Now I have to look at MOVIES and TV_SHOWS.
I’m not ungrateful - I’m just saying there is a “correct PLEX way” but the klunky way my son set this up 10+ years ago also worked, albeit with some file renaming.
The big learning from you is to RTFM [read the friendly manual].
Thanks again JaysPlex7, tom80H and smann for bearing with my old-fashioned method AND for being so kind and hospitable in your replies.
Jim [age 74] near St. Louis MO.
