Server Version#: 1.21.3.4021
Player Version#: 8.12.4.22902
This is the structure I am using to set up my tv programs (see below). I have a problem in that (If you look at the third line where it says “Season 01”) on the player it shows a white folder with Season 01 also in white letters over laying the folder so that you can not read it. I believe the title/season # used to be under the folder and possibly in black lettering (possibly not). It is hard to tell which folder (season) you are entering into. Thank you for any input.
TV Shows <— The library points here
---------TV Show Name (Year first aired if needed) <— This folder holds the season folders
------------------Season 01 <— This folder holds all the episodes for season 01
-------------------------ShowName - s01e01 - Episode Name.ext
-------------------------ShowName - s01e02 - Episode Name.ext
-------------------------And so on for the rest of season 01
------------------Season 02 <— This folder holds all the episodes for season 02
-------------------------ShowName - s02e01 - Episode Name.ext
-------------------------ShowName - s02e02 - Episode Name.ext
-------------------------And so on for the rest of season 02
------------------Season 03 <— This folder holds all the episodes for season 03
-------------------------ShowName - s03e01 - Episode Name.ext
-------------------------ShowName - s03e02 - Episode Name.ext
-------------------------And so on for the rest of season 03
---------2nd TV Show Name (Year first aired if needed) <— This folder holds the season folders
-------------------------2nd ShowName - s01e01 - Episode Name.ext
-------------------------2nd ShowName - s01e02 - Episode Name.ext
-------------------------2nd ShowName - s02e01 - Episode Name.ext
-------------------------2nd ShowName - s02e02 - Episode Name.ext
-------------------------2nd ShowName - s03e01 - Episode Name.ext
-------------------------2nd ShowName - s03e02 - Episode Name.ext
