Force intro and credit detection for unprocessed items?
I’ve put together a new machine, and decided to rebuild the plex libraries using .plexmatch files and re-arranging the migrated data.
I figured I’d let it spin after each new block of items added to have intro and credits detection on all of the content - but it seems to only partially process newly added stuff, and putting the rest in queue for the scheduled task that detects the missing ones every now and then when system is idle.
Is there a way to make it process all non-processed items in library so intro and credits status will be at 100% for the libraries when I’m done setting it up? Letting it run as a scheduled task would take months, or even years, as it only seems to process a few files each time, and I’d rather just do it now, when the server does not have any load.
If not force-detect, can I force-put the server in maintenance mode to process more files?
I’m also missing a dashboard where I can check which shows have 100% intro detected, at this point I have to rely on third party tools to read the database, and I’m not really comfortable with messing with the database using unofficial tools.
Incorrect. Scheduled tasks are processed every day, within the defined time span under Settings - Server - Scheduled Tasks
If you want the server to spend more time on them, simply extend this time span.
Intros are also (re-)detected if you manually trigger Analyze on the first episode of a season.
For credits to get detected, you’ll have to trigger Analyze on each individual episode. Though it is possible to multi-select the episodes of the whole season and then trigger Analyze.
That way you can analyze the shows you are currently watching manually, and let the rest be handled by the scheduled tasks.
