Forced subtitles no auto configured
Fire TV Stick doesn’t automatically show forced subtitles, which it does in my smart TV apps (LG, Samsung …).
On Fire TV Stick I have to manually enable them when I add a new movie.
In mkvtoolnix I always activate the subtitles as forced and in the other players I do not find problems in this regard. I have also tried various options on the Fire TV Stick with no solution to the problem.
Plex server I have it well configured, otherwise it would not work well in my Smart TV’s.
The subtitles are inside the MKV container, they are not external subtitles.
(Spanish… Google Translator)
Have you configured your language preferences for audio and subtitles in the account settings?
https://app.plex.tv/desktop/#!/settings/account
Audio & Subtitle Settings
Yes, i always leave only forced subtitle with mkvtoolnix. In the other players I have (Hisense, Samsung and LG) they do activate automatically.
Captura de pantalla 2021-12-12 124012
Thanks for answering!!
EDIT: same problem with all 3 Fire TV Stick players that I have
From app/plex.tv… I have done the same for each managed user and now I see that it automatically enables forced subtitling.
I did not know that I had to do it for each managed user, I believed that from the server it was enough. The weird thing is that in the Smart TV’s he did put them auto
Solved, thank you!!!
