Forcing Folder view as default
YES PLEASE! My family members all complain about this not being an option.
Please add this option as default, since is so annoying to have all the content in a messy way at the beginning and every single time i am forced to click on folder view…
Yes me too, its so annoying. I wish they fixed this
This coming via the UNO client/app which is being deployed across platforms over time.
When I set my photo or music libraries to folder view, they remain in that view across sessions. I don’t have to keep switching back to folder view manually as some are reporting. Am I not understanding the issue here?
It depends if you’ve got UNO on your platform or not. If you do and you want the tab selection remembered there’s a Plex setting for it.
I’m just using the default web client and don’t even know what UNO is. My guess is it’s not installed, but I’ll do some reading to learn what UNO is to be sure. Still feeling rather clueless when it comes to Plex…
https://forums.plex.tv/t/plex-web-with-uno-ui/414286
Also, you might want to look into a full-blown client for your desktop (Plex Media Player). https://www.plex.tv/media-server-downloads/#plex-app
Nothing yet??? Since 2013??? They not even read our post I guess. This is so bad Plex team. So BAD! I want folder view as default too.
Already mentioned above by @darcilicoous, if you have. `remember selected tab" enabled in settings. your library will stay however it was when you left it in that app.
http://app.plex.tv is always the newest web client currently version 4.x which has the UNO interface she spoke of. I don’t have a date for the local web client to have it.
(app.plex.tv does not send your media or library out to the internet and back if that is why you don’t use it.)
This affects Smart Tv apps? This is the only way I use Plex.
Thanks for the answear.
Not all Smart TVs are the same, which do you have?
One Samsung with Tizen and one LG with webOS.
What version of the Plex app do you have on the Samsung?
if the model you have has been updated to the UNO interface the setting should be here.
