Forget Known Network Tuners for Live TV
Server Version#: Docker: latest
I use VBox with Plex. I have recently reset my VBox and performed a channel re-scan, which has now picked up more channels than previously.
Prior to resetting the VBox, I deleted the DVR in Plex, ready to re-add the VBox as a tuner once reset. However, now that the VBox is reset, when I try to add the VBox to Plex, it still has old tuner data (old number of channels etc). Attempting to add the VBox using this old configuration results in a tuner error.
I need Plex to ‘forget’ all previously known network tuners. How can this be done? I assume it is a simple case as deleting a file in the Plex Application Library?
Many thanks,
Josh
See Delete All Tuner Data - #2 by OttoKerner
Worked a charm, thanks!
I assume that a more user friendly way to delete all DVR data has been requested from the development team?
