French Metadata agent released.
and first external Plex 9 plugin ;-)
Hi
French speaking Plex users, you can fin in the link below the Ciné-Passion metadata agent.
Thanks for the Plex 9 dev team, the API is so easy to use.
[s]Ciné-Passion Metadata Agent & Starting guide with Plex 9 in French [/s](content no more availabel)
Super B)
I suppose Ciné-Passion uses XML-RPC too and you need an API key to start a session ?
The Dutch moviemeter.nl site also uses XML-RPC and needs an API key.
If i would have time to write a agent for it i would, unfortunately at the moment time is not my friend.
Maybe there are takers to write an agent for moviemeter.nl . I only would do it myself if i can support it like when there are changes/new features in the moviemeter API and i can answer question/problems users have.
But oncleben31 just proved that writing an agent isn’t all that hard if you have some programming experience. I’m just guessing here that you have programming experience oncleben31 :smiley:
I’ve some programming experience but I’m not an expert. Plugin are in Python and use object API well developed by the Plex dev team.
I’ve watcht how the other metadata agents are done, and adapt to the Ciné-Passion database.
The most difficult thing was to have an algorithm to avoid wrong results because the search engine of Ciné-passion was not good enough.
Oncleben rocks, he was able to to write the first “third party” agent without any documentation. Thanks for all the great feedback during the process!
No glory, I’ve just reverse engineered the very well developed IMDB metadata agent.
And the API rocks !
Metadata agent have been updated : http://oncleben31.cc…-v1-3-released/
I think I was the first bilingual metadata agent and now I’m the first with preferences. “Oncleben31 first on metadata agent :lol:”
V1.4 Released for fixing the issue with Plex 0.9.1.5. And now I’m the agent is the first to manage collections :wink:
See http://oncleben31.cc…-v1-4-released/
Merveilleux, testons gaiement :rolleyes:
Thanks OncleBen B)
