Server Version#: 1.42.2.10156
Player Version#: 5.93.2 Platform V9
When playing media that requires only audio transcoding the reproduction freezes after short time or when forwarding or rewarding the video.
When the media requires transcoding for both video and audio there is no problem
Issue well documented already by user @r2_d21 in the following posts:
https://forums.plex.tv/t/playback-freezes-overzealous-client-range-could-not-be-satisfied/878685
Best workadound found so far is to change the playback bitrate (More, Settings, Video Quality, select any quality other than the original). This forces the video to be transcoded to a different bitrate, keeping the quality as close as possible to the original video file, not having to downgrade the video to a different resolution.
Any way to check if this bug has already been considered for fix?
