Playback freezes (overzealous client, range could not be satisfied)
Server Version#: 1.40.2.8395
Player Version#: 5.82.2 (Tizen)
I reported this 4 months ago and nothing has changed since then. The thread was closed and the issue has never been addressed.
Previous thread Playback freezes on Samsung TV when transcoding the audio. The problem happens when the audio is transcoded and the video is played directly.
I can reproduce this only on TVs when the audio is EAC3 or DTS, which Samsung decided to ignore.
I’ve spent 10k EUR on my home cinema and can’t use that. Can I have a reply from Plex at least? I’m not even asking for an ETA. Can I report this as a bug anywhere so it is not just silently closed again? I’m spending time describing the problem here no one cares about.
Same issue here, same log errors.
Happens on some but not all audio transcodes while direct streaming video (there seems to be a correlation with bitrates over 30mbps, all my files over 30mbps have the issue but under dont).
No issue while transcoding both audio and video
I have same issue. I changed the the setting to force direct play in the video settings and that seems to resolve the issue.
But then breaks other stuff as the sound on certain contents is non existent.
Yeah I’ve had it work when forcing direct play too, however it appears to be extracting the compatability audio, e.g. a truehd+Atmos track shows up as DD+ on my receiver when forcing direct play
Another issue is the Tizen app won’t direct play a audio track other than the default so if I select the eac5.1 track it will still try and transcode which fails
Player Version#: 5.85.0
The issue is not fixed. I think it even got worse.
same isue here with newest Samsung S95D
Overzealous client asked for end range of 2611241884, content size is 427085; we’ll clip.
when playing DTS content and plex client on TV is doing the audio transcode
without audio transcode (direct play) the movie plays fine but no sound
after about 60s of buffering error message “playback error”
PMS is on QNAP
any solution how to play DTS movies on a samsung TV?
here a working DTS file
here a nonworking DTS file buffering always at 48s
Same issue for me unfortunately, Q900C with Client 5.85.0; Very frustrating :frowning:
playing movie with
Video 3840x1634
Buffer 3840x1640
will buffer at about 50s in and finally crash
same movie in another version with normal
Video 3840x2160
Buffer 3840x2160
plays flawless, with otherwise same codecs
I also have this problem with my Samsung S90C but not on my slightly older Samsung Q80A
The S90C is running client version 5.85.0 - Platform Version 7
The Q80A is running client version 5.85.0 - Platform Version 6
Both TVs can direct stream the Video and have to transcode the Audio, within a minute the S90C will freeze and the media server log will be flooded with “Overzealous client” messages. The PMS transcodes the Audio without issue for the Q80A.
You can force Plex to transcode the video by choosing a different quality as a workaround. This would destroy HDR of course, if present.
It is interesting if enabling the video transcoder prevents the audio transcoder from crashing!
I’ll have a test tomorrow when I return home just for curiosity.
In the meantime, I’ve duplicated all the incompatible files in my library and made a second copy just for my S90C, which has removed all the extra audio streams so that only a single audio stream remains with either AAC, AC3 or EAC3 format. I’m fortunate that I have an abundance of storage available as this added just over 20Tb.
Due to the quirks of the Samsung player even if the MKV contains a compatible audio stream (AAC, EAC3) it will still transcode the audio if that audio is not the primary stream. Plex prioritises audio channel count over compatibility, so the default will usually be the DTS or TrueHD tracks, which are usually 7.1. If you select the second compatible audio track it will transcode even though it is supported which is a bit of an annoyance.
Forcing the video to transcode does not prevent the audio transcoder from crashing on my device!
We may have a different problem then, because in my case, transcoding the video fixes the problem in 100% of cases.
Freezes after a few seconds when direct streamed with transcoded audio
Screenshot 2024-09-17 at 20.19.16
Works when transcoded to any quality
Screenshot 2024-09-17 at 20.19.42
