Further tuners / Sat->IP Support?
Hi there,
I really like the UI of this.There are several channels for a variety of PVR systems/softwares… How does the HDHomeRun device work here? Is it just sending a stream to the plex server or is PMS actually using a user space tuner driver/kernel module?
Also, how about looking into adding SAT->IP support? With that we could easily add a lot of hardware. Even PCI/PCIe based DVB/ATSC cards can be used with nifty little software like minisatip or satpi, which are Opensource Sat->IP servers.
Are you going to share more details?
Cheers
Alex
Yup SAT>IP would be an excellent addition.
+1
SAT > IP support would allow a much wider device support ( i.e. DVB-S2 here in UK / Europe). A lightweight SAT > IP server on a IoT device ( Think PiZero) would allow a huge amount of legacy / existing USB tuners to be supported with very relatively small amount of work. It would also sit well with the Server / Client ethos which many Plex users prefer over Kodi etc.
There is a very promising approach here
And I am confident the Plex team will deliver robust APIs later, …, let them work on their plain and us see what comes next.
+1 for SAT>IP integration.
FYI - If you’re a Plex Pass member you can vote on the Feature request for Sat > IP here - https://forums.plex.tv/discussion/246282/feature-request-sat-ip-for-dvr
You vote by liking the thread post. There are detailed instructions in the Feature Request forum. You can’t load this sub forum unless you’re a Plex Pass member sonif the link fails check that you’re logged in.
