Getting Ready Loop
Had plex for last 5 years. Last night started to get a “Getting Ready” Error. Cannot access Server at all as it is just a blank black page.
At a complete loss what to try next.
Tried:
  • installing/reinstalling Plex Server
  • Logging into another plex account (via desktop link - not server)
  • using different browsers
  • Setting DNS to 8.8.8.8/1.1.1.1
  • Refreshing DNS
  • Refreshing IP
  • Restarting 20 times (after each change)
  • Deleting Registry
  • Deleting User files
  • Deleting Program Files
  • Setting New Pin/Removing Pin
  • Resetting Password
Cannot claim server as there are no options because Plex server will not load and is stuck on “Getting Ready”.
Logs show the following:
  • Request: [127.0.0.1:61796 (Loopback)] GET /myplex/launch (2 live) #398 GZIP Token ()
  • [Req#398/HCl#1e0] HTTP requesting POST https://plex.tv/api/v2/pins?strong=true
  • Completed: [127.0.0.1:61796] 200 GET /myplex/launch (2 live) #398 GZIP 0ms 3488 bytes (pipelined: 272)
  • [HttpClient/HCl#1e0] HTTP error requesting POST https://plex.tv/api/v2/pins?strong=true (35, SSL connect error) (Recv failure: Connection was reset)
  • [Req#398] MyPlex: Failed to retrieve PIN: -35
Stop the server for 20 minutes and see if that fixes it. (could be cert retry throttling) otherwise post a copy of your server logs.
Jan 01, 2026 15:35:05.592 [24556] ERROR - [Req#24] MyPlex: Failed to retrieve PIN: -35
Jan 01, 2026 15:35:06.539 [19876] DEBUG - Request: [127.0.0.1:51762 (Loopback)] GET /myplex/launch (4 live) #25 GZIP Token ()
Jan 01, 2026 15:35:06.539 [8200] DEBUG - [Req#25/HCl#19] HTTP requesting POST https://plex.tv/api/v2/pins?strong=true
Jan 01, 2026 15:35:06.539 [3340] DEBUG - Completed: [127.0.0.1:51762] 200 GET /myplex/launch (4 live) #25 GZIP 0ms 3488 bytes (pipelined: 8)
Jan 01, 2026 15:35:06.625 [16840] WARN - [HttpClient/HCl#19] HTTP error requesting POST https://plex.tv/api/v2/pins?strong=true (35, SSL connect error) (Send failure: Connection was reset)
Jan 01, 2026 15:35:06.625 [8200] ERROR - [Req#25] MyPlex: Failed to retrieve PIN: -35
Jan 01, 2026 15:35:07.553 [19876] DEBUG - Request: [127.0.0.1:51762 (Loopback)] GET /myplex/launch (2 live) #26 GZIP Token ()
Jan 01, 2026 15:35:07.553 [19768] DEBUG - [Req#26/HCl#1a] HTTP requesting POST https://plex.tv/api/v2/pins?strong=true
Jan 01, 2026 15:35:07.554 [9268] DEBUG - Completed: [127.0.0.1:51762] 200 GET /myplex/launch (2 live) #26 GZIP 0ms 3488 bytes (pipelined: 9)
Jan 01, 2026 15:35:07.639 [16840] WARN - [HttpClient/HCl#1a] HTTP error requesting POST https://plex.tv/api/v2/pins?strong=true (35, SSL connect error) (Recv failure: Connection was reset)
Jan 01, 2026 15:35:07.639 [19768] ERROR - [Req#26] MyPlex: Failed to retrieve PIN: -35
Jan 01, 2026 15:35:07.646 [19768] DEBUG - DVR:Device: Discovering and refreshing all devices.
Jan 01, 2026 15:35:07.646 [19768] DEBUG - Grabber: HDHomerun discovered 0 compatible devices.
Jan 01, 2026 15:35:07.646 [19768] DEBUG - [HCl#1b] HTTP requesting POST http://127.0.0.1:32600/devices/discover
Jan 01, 2026 15:35:08.705 [10248] DEBUG - [NSB/SSDP] Parsing SSDP schema for http://192.168.0.236:55000/dms/ddd.xml
Jan 01, 2026 15:35:08.720 [24560] DEBUG - Grabber: Cleaning up orphaned grabs.
Jan 01, 2026 15:35:08.720 [24560] DEBUG - Grabber: Cleaned up 0 decrepit directories in 0.0 sec.
Jan 01, 2026 15:35:08.720 [24560] DEBUG - Activity: registered new activity 9d834c52-8a1e-4709-9e29-1ab32efd96d7 - “Processing subscriptions”
Jan 01, 2026 15:35:08.720 [24560] DEBUG - Subscription: Scheduling subscriptions.
Jan 01, 2026 15:35:08.721 [24560] DEBUG - Subscription: Initialized 0 schedulers.
Jan 01, 2026 15:35:08.721 [24560] DEBUG - Subscription: Starting with 0 grabs, scheduled 0 active ones preemptively.
Jan 01, 2026 15:35:08.721 [24560] DEBUG - Subscription: Scheduled all subscriptions in 0 ms.
Jan 01, 2026 15:35:08.721 [24560] DEBUG - Activity: Ended activity 9d834c52-8a1e-4709-9e29-1ab32efd96d7.
Jan 01, 2026 15:35:08.721 [24560] DEBUG - Subscription: There are 0 active grabs at the end.
Jan 01, 2026 15:35:08.721 [24560] DEBUG - Activity: Ended activity b151c08a-d859-4638-9c6a-7ad585df3345.
Jan 01, 2026 15:35:08.721 [24560] DEBUG - Subscription: Refreshed all content in 0 ms.
Jan 01, 2026 15:35:08.818 [16840] DEBUG - [HttpClient/HCl#1c] HTTP/1.1 (0.1s) 200 response from GET http://192.168.0.236:55000/dms/ddd.xml
Jan 01, 2026 15:35:08.819 [10248] DEBUG - [NSB/SSDP] found 1 SSDP devices via http://192.168.0.236:55000/dms/ddd.xml
Jan 01, 2026 15:35:08.819 [10248] DEBUG - [NSB/SSDP] SSDP arrived: 192.168.0.236 (VIERA GT50 Series)
Jan 01, 2026 15:35:08.819 [10248] DEBUG - [NSB/SSDP] Parsing SSDP schema for http://192.168.0.1:1900/zymwh/rootDesc.xml
Jan 01, 2026 15:35:08.821 [16840] DEBUG - [HttpClient/HCl#1d] HTTP/1.1 (0.0s) 200 response from GET http://192.168.0.1:1900/zymwh/rootDesc.xml
Jan 01, 2026 15:35:08.821 [10248] DEBUG - [NSB/SSDP] found 3 SSDP devices via http://192.168.0.1:1900/zymwh/rootDesc.xml
Jan 01, 2026 15:35:08.821 [10248] DEBUG - [NSB/SSDP] SSDP arrived: 192.168.0.1 (Archer AX53)
Jan 01, 2026 15:35:08.821 [10248] DEBUG - [NSB/SSDP] SSDP arrived: 192.168.0.1 (WANDevice)
Jan 01, 2026 15:35:08.821 [10248] DEBUG - [NSB/SSDP] SSDP arrived: 192.168.0.1 (WANConnectionDevice)
Jan 01, 2026 15:35:08.821 [10248] DEBUG - [NSB/SSDP] Parsing SSDP schema for http://192.168.0.33:1099/
Jan 01, 2026 15:35:08.825 [16840] DEBUG - [HttpClient/HCl#1e] HTTP/1.1 (0.0s) 200 response from GET http://192.168.0.33:1099/
Jan 01, 2026 15:35:08.825 [10248] DEBUG - [NSB/SSDP] found 1 SSDP devices via http://192.168.0.33:1099/
Jan 01, 2026 15:35:08.825 [10248] DEBUG - [NSB/SSDP] SSDP arrived: 192.168.0.33 ([LG] webOS TV UF770V)
Jan 01, 2026 15:35:10.135 [16840] DEBUG - [HttpClient/HCl#1b] HTTP/1.1 (2.5s) 200 response from POST http://127.0.0.1:32600/devices/discover
@LordXilos Please see the article on server logs on how to get a zip of your logs. A random excerpt is rarely going to contain the needed information.
