Ghost tuner device - How do you kill zombies in the database?
Server Version#: 1.13.8.5395
Player Version#: NA
OS: Linux
Tuner: HDHomeRun Connect
I’m seeing attempts by the server to contact an old hdhomerun tuner that is no longer showing up in the GUI config. This appears to be similar to one of the issues noted in the following topic:
I upgraded from an HDHomeRun Connect to a Conect Quatro (to address recording conflicts on busy days). The old Connect tuner was removed via the GUI admin page, and only the new Quatro is currently listed as a valid device. But, it appears that the database entry for the old tuner was not properly cleaned up, and the server keeps trying to contact the old device/IP:
Oct 14, 2018 09:52:02.713 [0x7f23d9ffd700] WARN - HTTP error requesting GET http://10.0.0.16:80/discover.json (0, No error) (Failed connect to 10.0.0.16:80; No route to host)
Oct 14, 2018 09:52:02.727 [0x7f23d9ffd700] ERROR - DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/1042E075, marking as dead.
Is there a way to fully purge this old ghost entry from the database to avoid unnecessary startup thrashing and potential issues down the road?
Thanks.
Same issue.
I had Telly installed at one time, which uses port 6077.
Oct 29, 2018 00:49:54.136 [2908] WARN - HTTP error requesting GET http://192.168.0.99:6077/discover.json (0, No error) (Failed connect to 192.168.0.99:6077; No error)
Oct 29, 2018 00:49:54.151 [2908] ERROR - DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/12345678, marking as dead.
I wonder if I can use SQLite to manually remove these.
