Keep getting log errors about HDHomerun Media tuners removed long ago
Server Version#: 1.40.1.8227-c0dd5a73e
Player Version#: n/a
Tuner Make/Model: various hdhomerun
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Keep getting the following repeated in the logs for old tuners I’ve removed:
Mar 29, 2024 15:25:30.115 [22480530393912] WARN - [HttpClient/HCl#143a] HTTP error requesting GET http://192.168.0.252:80/discover.json (7, Couldn’t connect to server) (Failed to connect to 192.168.0.252 port 80 after 3060 ms: Couldn’t connect to server)
Mar 29, 2024 15:25:30.116 [22480462400312] ERROR - [NSB/SSDP] DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/1054A494, marking as dead.
Mar 29, 2024 15:25:33.187 [22480530393912] WARN - [HttpClient/HCl#143b] HTTP error requesting GET http://192.168.0.46:80/discover.json (7, Couldn’t connect to server) (Failed to connect to 192.168.0.46 port 80 after 3070 ms: Couldn’t connect to server)
Mar 29, 2024 15:25:33.189 [22480462400312] ERROR - [NSB/SSDP] DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/10802B82, marking as dead.
There is also a reddit post that describes my situation and others having the same issue. I’m not comfortable editing the database and wondering if there is another solution?
https://www.reddit.com/r/PleX/comments/101qwey/plex_still_tries_to_connect_to_removed_hd_homerun/
