I am currently running
PLEX Version 1.13.8.5395 on a
Synology DS1817+ running DSM 6.2-23739 Update 2.
I recently replaced HDHomeRun Quattro (was at IP 192.168.1.156) with a HDHomeRun Extend (now sitting at IP 192.168.1.117) and I can watch live tv through PLEX without an issue, but when I try to record I keep seeing the following messages below in “Plex Media Server.log” where PLEX is still trying to connect to the old HDHR box. The old DVR was removed before the 192.168.1.156 was disconnected from my network, if that matters.
Sep 24, 2018 23:54:54.707 [0x7f86427ff700] WARN - HTTP error requesting GET http://192.168.1.156:80/discover.json (0, No error) (Failed connect to 192.168.1.156:80; No route to host)
Sep 24, 2018 23:54:54.773 [0x7f86427ff700] ERROR - DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/1073980D, marking as dead.
Sep 24, 2018 23:55:06.502 [0x7f863efff700] ERROR - Error issuing curl_easy_perform(handle): 28
Sep 24, 2018 23:55:21.520 [0x7f863efff700] ERROR - Error issuing curl_easy_perform(handle): 28
Sep 24, 2018 23:55:36.536 [0x7f863efff700] ERROR - Error issuing curl_easy_perform(handle): 28
Sep 24, 2018 23:55:51.551 [0x7f863efff700] ERROR - Error issuing curl_easy_perform(handle): 28
Sep 24, 2018 23:56:06.567 [0x7f863efff700] ERROR - Error issuing curl_easy_perform(handle): 28
I have already tried deleting the new DVR in the settings, shutting down PLEX, restarting, and adding the new DVR box again, the HDHomeRun Extend (now sitting at IP 192.168.1.117)… and I am still seeing the message in the logs that PLEX is still trying to conect the “ghost device”, and recordings say that they are running looking in status, I see files being added to my transcoder temp directory while it says it is recording a show, but then, when the show ends… the shows does not ever show up in the library the DVR is recording to … Please help!
Full Logs attached, after shutting down PLEX, clearing all previous logs, and starting PLEX back up and trying to record a show via the DVR.
Plex Media (37.5 KB)
