I have a particular episode of James Corden (don’t judge me) that keeps appearing in the FILM section. I have deleted it thoroughly, but each JC episode that is downloaded after suddenly comes up in the film section with the ORIGINAL TITLE OF THE TROUBLESOME EPISODE. I love PLEX but am currently PERPLEXED. Any suggestions?
Media
Duration 39:24
Bitrate 3108 kbps
Width 1280
Height 720
Aspect Ratio 1.78
Video Resolution 720p
Container MKV
Video Frame Rate NTSC
Audio Profile lc
Video Profile high
Part
Duration 39:24
File james.corden.2022.09.21.tyra.banks.mkv
Size 876.11 MB
Audio Profile lc
Container MKV
Video Profile high
Codec H264
Bitrate 3108 kbps
Bit Depth 8
Chroma Location left
Chroma Subsampling 4:2:0
Coded Height 720
Coded Width 1280
Color Primaries bt709
Color Range tv
Color Space bt709
Color Trc bt709
Frame Rate 29.97 fps
Height 720
Level 4.0
Profile high
Ref Frames 5
Scan Type progressive
Width 1280
Display Title 720p (H.264)
Extended Display Title 720p (H.264)
Codec AAC
Channels 2
Language English
Language Tag en
Audio Channel Layout stereo
Profile lc
Sampling Rate 48000 Hz
Display Title English (AAC Stereo)
Extended Display Title English (AAC Stereo)
Codec SRT
Language English
Language Tag en
Title English [SDH]
Display Title English (SRT)
Extended Display Title English [SDH] (SRT)
View XML
So… you say that all future James Corden episodes download, and appear in your “Movies” library?
Makes sure you don’t - for some reason - have your Movie library index a folder where you download JC episodes to. Check the folder sources you are targeting for that library to see if you have a temporary or “downloads” folder indexed.
And of course make sure your downloader program isn’t simply dumping new episodes to the wrong location (Movies) rather than the show in your “TV Shows” library.
Oh, and don’t download directly into your media folders. Particularly not if you have automatic or periodic library scans activated.
Always use a “staging” folder that lies outside of the media folder structure of Plex.
Only after the download/rip is finished and the file name has been perfected, move the file into the media folder.
I’ve noticed that Plex has pretty decent support for the standard internet naming format for the date-based shows like those used by late-night shows. Files can be added to Plex as-is name-wise.
It’s not ideal if you plan to keep these shows for a long time, but I think it’s sufficient to let it just detect the show with the existing name, watch, then delete.
@danban71 Show us screenshots of your TV library Edit → Advanced.
I can’t explain the Plex TV Series Agent/Scanner marking anything as film.
Suggest you use the name of the show or its tvdb id. The Late Late Show with James Cordon {tvdb-292421}
Plex Dance that whole series, batch rename the files and folder with the correct title. I wouldn’t worry about the dates unless it chokes like Divideby0 said. The following worked when I tried it with Plex TV Series agent/scanner.
/share/TV/The Late Late Show with James Corden/Season 08/the.late.late.show.with.james.corden.2022.09.21.tyra.banks.mkv
In my library, I would follow the Plex naming scheme exactly (more future proof and faster matching).
/share/TV/The Late Late Show with James Corden/Season 08/The Late Late Show with James Corden - 2022.09.21 - tyra.banks.mkv
