Server Version#: Version 1.19.4.2935
Player Version#: Plex for Samsung Tizen 4.29.6 3.0
Player Version#: Plex for LG 5.0.12 4.1.0
Hi ChuckPA
Getting a bit desperate , I know that you are a linux guru, so I hope that I might can get some assistance from you.
For starters I can say that PMS works fine on the Synology, no issues.
Then I have:
Intel NUC with Ubuntu Desktop running PMS
Synology DS1019+ Raid 6
I have created a “server” user on the Synology with RW permissions on my Media folder.
I have installed cifs-utils on my Intel NUC so I can mount the shared folder on the Synology.
On my NUC I have created a mount folder /home/plex/Synology
The mount command I use is:
sudo mount -t cifs -o username=server,password=thepasswordImade,uid=1000 //192.168.0.2/Media ~/Synology
Once that is done, I can see the media content on my /home/plex/Synology folder, so far so good. I add directories in Plex, indexing, works.
I have Animations4K and 4K which is movies.
On my Samsung TV I can play the animation I choose, works without any issues. On the LG the tv stutters and is laggy. Same media. I tried to move the cables around from one switch to another , makes no difference.
Anyways here comes the strange part
My 4K movie folder isnt updating meta data now, I cant play anything from that directory. I checked permissions and it seems to look exactly the same. It worked yesterday and all good.
After I was done testing, I demounted the folder on the nuc, shutdown the NAS .
Today remounted , and now I cant play anything in the 4K folder, animation4K still works on my Samsung without any problems, LG still the same stuttering?
Do you have any ideas what im doing wrong here?
I tried NFS but either im doing something seriously wrong, or I cant seem to get it work proberly. It seems that cifs seem better somehow.
Morphy
