Hi
Hopefully some one has an answer to this issue, i have uploaded the entire Midsomer Murders Seasons & im having problems,
1: I’m struggling with how to break apart show episodes that were improperly grouped together, on the season, they are all in the same place, it shows up as 1 episode, but when i go deeper into it, there is say 6 or 7 in a group. Ive attached a couple SS, to show what i mean!
How do i ungroup them please?
2: I have uploaded all 20 seasons but only a few are appearing, they are all labelled in the same way on my DSM.
seasons|690x388
Hopefully someone has had this issues & can help me please?
Any more info anyone needs to help, please let me no.
Thanks!
Step One:
With LMA in priority, Embedded Titles within MP4/M4V files are preferred - even over a perfect file name. Local Media Assets should - AT ALL TIMES - remain enabled (unless specifically instructed to turn it off).
Local Media Assets should be ‘Demoted’, to the bottom of the stack of active agents under ALL tabs in Shows and Movies, but should NOT be disabled.
Local Media Assets is needed for many things - it doesn’t need to be given Tip-Top-Priority (as Plex has so hatefully placed it as it’s …
Step Two:
(If you expect Plex to find, index and match your media - follow the instructions):
https://support.plex.tv/articles/categories/your-media/naming-and-organizing-tv-shows/
Possible Third Step - if Refresh Metadata after ‘the repairs’ doesn’t do much:
The purpose of this is to remove all cached metadata and xml data for an item that Plex usually keeps. This helps when you want to “start from scratch” for particular item
move all files for the media item out of the directory your Library is looking at, so Plex will not “see” it anymore
scan the library library (to detect changes)
empty trash
clean bundles (in menu next to server name, when accessed under ‘More’)
double check naming schema and move files back
scan the library
Support articl…
Thanks, The LMA thing sorted it.
