Guys please help!
Hey everyone. I dont know whats going on but I can connect to Plex from my laptop no problem and play. However now when I try the Ps4 or Iphone it is not working at all anymore. It cannot find the server. So for instance the name Jimbo which is my server name just says connecting on my iphone and does nothing, its as if it isnt there or exists. PC works fine and loads all content that is why im confused. Ive tried everything. Please help I miss Plex:(
What happens when you open the Browser on PS4 and open internal-PMS-IP:32400/web/ ?
not sure I am following sorry
Makes no sense whatsoever. PS4 doesnt work anymore and Iphone doesnt find my server at all… If i cancelled and redid Plex would it work?
since it doesn’t work both on PS4 and iOS I would say your issue is on the server side, make sure your server isn’t blocked by firewall.
Here are somethings you can do to solve any issues,
restart the server machine,
re-install the plex server
signout and sign in from the server
maybe install the server server on a different machine to see if that works.
