Handle chaotic anime folders better
I’m not a neat person at all when it comes to my PC. I just throw whatever I want to watch into my downloads folder, and empty that when it’s too full.
The anime I watch often follows a naming scheme like this:
[ReleaseGroup] Show Title - 99 [1080p].mkv
And this seems to really confuse Plex.
I tried to add my Downloads folder into Plex in TV show mode, and it acted as if there were no video files in that folder at all. Give or take a few differences (some add additional [brackets] with things like audio info, or sometimes there’s a checksum at the end), anime file names are almost always like this, so I was surprised that it wouldn’t recognize anything at all.
For the time being, I put my library in movie mode and it works fine, but it won’t group episodes of the same show together. It’s a bit unfortunate.
I really wish you’d find a way to improve this. I’d like some auto-organization of my shows without having to rename and organize things I’ll delete soon anyway.
If you’re not willing to / interested in organizing your files so Plex can catalog them properly… your best shot is to go with a “Other Video” type library.
https://support.plex.tv/articles/categories/your-media/naming-and-organizing-personal-media/
Thanks. I’ll give it a try. But ultimately, I’d really like it if Plex were able to manage and auto-categorize those like TV shows despite the chaos.
Plex is locked in at TVDB or TMDB.
If you don’t match with the database there’s not much Plex can do – at this time.
It’s a bit easier to use the Personal Media Agent:
Fix Match/Search Options/Agent/Personal Media.
That way you can have a ‘fairly chaotic’ structure system, but it still must adhere to general TV Show Structuring. In the end it’ll be easier to make a TV Show out of it than an Other Videos Library will.
You’ll have to hand edit, of course, but when you use Personal Media Plex will stop trying to match it - and blowing your edits every time it does.
Thanks! That’s an interesting idea. I’ll take a look.
plex is not designed for anime and if you have nested folders it wont work correctly. they need a proper anidb.net integration or use one of the third party plugins while they last before plex pulls the plug
