Hardware Accelerated Transcoding Option Not Appearing
Server Version#: 1.43.1.10611-720010611
Player Version#: 1.112.0.359-0d79a49f
Hello - have upgraded to Plex Pass several days ago, but am still not seeing option ‘Use hardware acceleration when available’ under [Server] > Settings > Transcoder. Running PlexMediaServer on Synology DS220+ - server is claimed by the account with the Plex Pass. Running directly on the server, not in a container. Would anyone know what could be the case here? I would have thought all criteria were fulfilled. Thanks in advance!
You might be experiencing the same issues people are running into that are documented in this thread.
I suggest you drop down to v1.43.0 or try out the test build located in this post.
https://forums.plex.tv/t/hardware-gpu-quicksync-transcoding-broken-on-beta-1-43-1-10540/937145/118
@FDM80 That problem is specific to systems with Arrow Lake CPUs.
@r_w7 Stop Plex Media Server. Wait 2-3 minutes. Start Plex Media Server. That should force it to check in with plex.tv and verify you have a Plex Pass.
If it does not work, pull and post a set of server log files.
Thanks both - turned out to be DNS issues on my end which I have since resolved. The option is now appearing as expected. Appreciate the assistance nonetheless.
how so? How did you resolve it?
@wearemazzeri to resolve DNS issues, reboot your modem/router and everything connected to it, including any wireless devices.
That should clear any DNS cache corruption that may be causing your issue.
