Hardware transcoding not working on debian
Hello,
I was currently trying my new P2000 under debian, and the drivers seems to be working as per:
| NVIDIA-SMI 418.197.02   Driver Version: 418.197.02   CUDA Version: N/A      |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  Quadro P2000        On   | 00000000:01:00.0 Off |                  N/A |
| 44%   31C    P8     4W /  75W |      1MiB /  5059MiB |      0%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|  No running processes found                                                 |
root@debian:/# htop
01:00.0 VGA compatible controller: NVIDIA Corporation GP106GL (rev a1) (prog-if 00 [VGA controller])
        Subsystem: Dell GP106GL [Quadro P2000]
        Physical Slot: 0
        Flags: bus master, fast devsel, latency 0, IRQ 46
        Memory at c1000000 (32-bit, non-prefetchable) [size=16M]
        Memory at 800000000 (64-bit, prefetchable) [size=256M]
        Memory at 810000000 (64-bit, prefetchable) [size=32M]
        I/O ports at d000 [size=128]
        Capabilities: [60] Power Management version 3
        Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [78] Express Legacy Endpoint, MSI 00
        Capabilities: [100] Virtual Channel
        Capabilities: [250] Latency Tolerance Reporting
        Capabilities: [128] Power Budgeting <?>
        Capabilities: [420] Advanced Error Reporting
        Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
        Kernel driver in use: nvidia
        Kernel modules: nvidia
01:00.1 Audio device: NVIDIA Corporation GP106 High Definition Audio Controller (rev a1)
        Subsystem: Dell GP106 High Definition Audio Controller
        Physical Slot: 0
        Flags: bus master, fast devsel, latency 0, IRQ 17
        Memory at c2000000 (32-bit, non-prefetchable) [size=16K]
        Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
        Capabilities: [78] Express Endpoint, MSI 00
        Capabilities: [100] Advanced Error Reporting
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
But when trying to transcode, it seems hardware acceleration is not working. Any idea?
Kind regards
Hello,
I installed nvidia-cuda-toolkit and it seems this error was solved:
Cannot load libcuda.so.1
But now receiving this error from plex:
This are the logs:
Hello,
It seems I made it to work on Ubuntu, but with other problems also: Plex kicking my playbacks when more than 2-3 transcodes
And I have tried on Windows, but impossible neither:
Plex Media Server.log (1.5 MB)
Any idea?
