Hardware Transcoding
Server Version#: 1.16.4.1469
This used to be worked awhile ago, but noticed it is not longer working. I have nvidia P2000 card, which when I watch a recorded video on my iPhone I see it show in status and all appears well. When I record live tv (HDHomeRun) I am getting mpeg-2.ts files. I have experimental transcoding turned on. Why am I not getting mp4 files?
would you please verify DEBUG logging is on , VERBOSE is off and recreate the first 30 seconds of playback,
then stop,
wait 30 seconds
download logs and attach
dvr tv will always be .TS files even if transcoding is enabled.
if you ‘get info’ instead of mpeg 2 they will be x264 constrained baseline.
Media
  • Duration 35:42
  • Bitrate 36917 kbps
  • Width 1920
  • Height 1080
  • Aspect Ratio 1.78
  • Video Resolution 1080p
  • Container MPEGTS
  • Video Frame Rate NTSC
  • Channel Identifier 4.1
  • Media Grab Begins At1565625600
  • Media Grab Devicedevice://tv.plex.grabbers.hdhomerun/10706B32
  • Media Grab Original Duration 3717751
  • Media Grab Post Processed1
  • Media Grab Statuscomplete
  • Origin dvr
  • Video Profile constrained baseline
Part
  • Duration 35:42
  • File The Young and the Restless (1973) - 2019-08-09 07 00 00 - 08-12-2019.ts
  • Size 5.06 GB
  • Container MPEGTS
  • Indexes sd
  • Packet Length 188
  • Codec H264
  • Bitrate 18139 kbps
  • Bit Depth 8
  • Chroma Location left
  • Chroma Subsampling 4:2:0
  • Closed Captions 1
  • Frame Rate 29.97 fps
  • Height 1080
  • Level 4.0
  • Profile constrained baseline
  • Ref Frames 1
  • Scan Type progressive
  • Stream Identifier 256
  • Width 1920
  • Display Title 1080p (H.264 Constrained Baseline)
