Has scanning for Local Media/Credits Listing been fixed?
Irrelevant, you can change it in the Server settings later.
certv2
Remove this file??
Enable the display of known file name extensions in the settings of Windows file explorer. Then you can see that this is indeed the file in question.
I didn’t see no prompt to claim a server, but I logged in on the clone PC and it just displays the one desktop, the old system is not listed.
You need to claim the server, after removing those items from the registry.
I hope you did that while plex server was closed/stopped/ended?
Under General it says this PC is claimed by
Server claimed by
chucksroofrepair@gmail.com, my email and thats what it says. The Desktop name displayed is the CLONE PC, not the original system.
Of course both plex media servers were shut down on both PCs.
Now put the side bar into the MORE… mode. (provided both servers are now running)
You should now see both servers in there, similar to my last screenshot above.
“pin” those libraries you want.
Oh you want me to start up the server on the original system then?
The whole set of actions you just did was to enable you to do that.
nope, now it switched me back to the old PC the moment I ran PMS on the old computer. I refreshed it on the new CLONE machine.
What do you mean with “refresh”?
I just refreshed the page on the clone PC.
ok now i stopped the PMS on the Clone PC and reloaded it and now it switched back to the CLONE machine, instead of the original source machine.
Did you mess with the list of authenticated devices?
It appears you have removed the original server from your account.
Whatever you did, you have now just one server on your account.
Which probably means that both machines are still using the same identity.
Which should not be possible, unless you copied the registry data again from machine to machine. Did you?
I don’t know, but right now there is nothing on my PS5 now. All my libraries are not displayed. I can access them on my computer but I don’t see nothing on my PS5.
No I didn’t change any authenticated devices after remove the reg entries. The only time I copied/backup the registery was when I was doing the full Cloning process.
Do you see both servers now in the side bar of the web app?
Is the PS5 signed into the same Plex user account as all the other devices?
No just shows the one desktop.
its the CLONE PC name that is being displayed, not the original server.
That is not the side bar I was referring to.
Your screenshot shows the settings side bar.
I meant the side bar when you are right on the home page.
