Server Version#: 4.159.0
Player Version#: 4.13.2 plexamp flatpak
When I try to open plexamp it does not open. I’m not seeing any error messages or any windows pop up, simply nothing happens.
When running via command line I’m seeing this error after running the command:
flatpak run -v com.plexamp.Plexamp:
F: Pulseaudio user configuration file ‘/home/user/.config/pulse/client.conf’: Error opening file /home/user/.config/pulse/client.conf: No such file or directory
F: Running ‘bwrap --args 41 – xdg-dbus-proxy --args=43’
F: Running ‘bwrap --args 41 – startplexamp’
[3:0519/111145.854507:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
LaunchProcess: failed to execvp:
xdg-settings
[3:0519/111146.152167:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[3:0519/111146.152217:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
Main: restoring window state from /home/user/.var/app/com.plexamp.Plexamp/config/Plexamp/window-state-plexamp-main.json
Main: Centering offscreen window.
Linux: Registering MPRIS service.
[3:0519/111146.466951:ERROR:ui/events/platform/wayland/wayland_event_watcher.cc:47] libwayland: [destroyed object]: error 7: failed to import supplied dmabufs: Arguments are inconsistent (for example, a valid context requires buffers not supplied by a
/app/bin/startplexamp: line 3: 3 Trace/breakpoint trap (core dumped) zypak-wrapper /app/bin/plexamp/plexamp “$@”
Tried looking into dbus issues but dbus seems to be running normally as far as I can tell. Not sure how to proceed. I tried uninstalling and reinstalling plexamp multiple times. Plex server is running normally and able to access music and all other libraries. Not sure what else to try, any help would be appreciated. thanks in advance
