Having problems connecting Remotely to Plex
Server Version#: 1.9.7.4460
Player Version#: Web/PS4/Android/Xbox etc
I have been having some problems with remote access the last weeks with my Plex. Havent changed anything at home, on the router or anything that should intervene.
I have tried everything I can think of, and sometimes it works for a little while, but after a few hours it doesn’t work again.
I have read through all off the troubleshooting, but nothing.
I have checked on my router and the portforwarding is still there, but when I test it, it says that the port is blocked. Any advise? My internet provider doesnt help with such requests.
What logs do you need from me? (since there are like billions xD)
Please post a shot of your port forwarding.
Is it rly safe to post a pic where ip adress shows?
^^^ it’s a bit old, I’d say.
Yeah I saw that xD
Updated it to 1.15.5.994 manually since the aqutomatic wasnt working.
Still problem with connecting though.
This is my Portforwarding in the router.
And this is how it looks in Plex (sorry for the swedish :P)
According to the instructions in your router, you onyl need to fill in the first ‘Start’ field and leave all other empty.
do this,
then check the function of the port forwarding with canyouseeme.org
