HDHomerun disappeared suddenly and can't be found/added again
I’ve had HDHomerun working on my Plex for years. All of the sudden it disappeared and when I click Setup Plex DVR it does not find it automatically nor by IP address nor host name. HDHomerun is def working, I can hit in the browser by IP address on the machine that Plex is hosted. There has been no changes to the machine. What gives?
Plex Media Server Logs_2021-06-26_09-47-25.zip (6.6 MB)
Server Version#: Windows Server 2016
Player Version#: 1.23.4.4712-1f0ed4aea
Tuner Make/Model: HDHomeRun PRIME HDHR3-CC Firmware: 20210624
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Can anybody help me please?
I usually don’t respond to Win because I don’t have a Win Plex Server instance, but since you aren’t getting any responses…
Did you by chance recently change where your Plex data folder is stored? In your “Plex Tuner Service.log” file I’m seeing this message repeated:
Jun 26, 2021 09:40:08.962 [7412] DEBUG - [I] file_tuner::get_stream_file. File C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private\devices\dvb\file\drv_file.ini does not exist
however, in your main “Plex Media Server.log” file I do see that you have your tuner defined:
Jun 26, 2021 09:17:15.778 [9708] DEBUG - HTTP/1.1 (0.0s) 200 response from GET http://192.168.1.211:80/lineup_status.json
Jun 26, 2021 09:17:15.799 [9708] DEBUG - Grabber: HDHomerun discovered 1 compatible devices.
Jun 26, 2021 09:17:15.799 [9708] DEBUG - DVR:Device: Testing grabber HDHomerun device device://tv.plex.grabbers.hdhomerun/131A545D at http://192.168.1.211:80
Jun 26, 2021 09:17:15.799 [9708] DEBUG - DVR:Device: Device device://tv.plex.grabbers.hdhomerun/131A545D was already known, refreshing database info
When I searched for the message about the missing drv_file.ini, I found instances where people had moved their Plex data folder and this issue had resulted.
Thank you @hokierulz for analyzing my logs! That’s the thing, I have not done anything to my Plex Windows server when my DVR setup just disappeared one day. I never move folders around.
So, it sounds like there is a conflict where one process things that the tuner is already defined while the other does not have what it needs to run it. So when I try to redo the setup it’s just spinning and spinning.
I have no idea how to tackle this. Can I recreate the ini file somehow? What’s in it? Can someone send me a sample? Or should I remove something somewhere else so it the server does not think it already has a tuner?
This thread discusses a problem that has symptoms similar to what you describe, though I can’t find a way to definitely confirm the same root cause. If it was me I’d follow the recommended procedure that has worked for some people: remove tv.plex.*.* files followed by a reboot, though if I were doing it I would backup those files someplace else first.
YES!!! @hokierulz you rock!
