HdHomeRun dissiperd and can not re add it
Continuing the discussion from HDHomerun wont connect to Plex anymore:
Server Version#: 1.25.4.5487
Tuner Make/Model: HdHomeRun Prime
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Same issue happened on other server and had to delete all of app data to fix and reset up the server… I don’t want to have to do the same thing to fix this server it is a ton of work and you loose all of your progress on played and un played content. Tried this KB HDHomerun wont connect to Plex anymore and did not work.
Try and setup HDHomerun again, and when failed, upload a zip with PMS logs
Plex Media Server.zip (43.8 KB)
It does not give an error it just spins and if I try to put in the IP manually it goes back to the spinning wheel screen.
Huh…From you logs:
Feb 18, 2021 17:17:39.685 [12020] INFO - Plex Media Server v1.21.2.3901-3491b3b47 - Microsoft PC x64 - build: windows-x86_64 windows - GMT -07:00
Very old, both the date as well as the version
I noticed that as well. This is the path I grabbed the logs form %LOCALAPPDATA%\Plex Media Server\Logs. Is there a way to force it to create fresh logs?
Does this registry key exsist?
HKEY_CURRENT_USER\SOFTWARE\Plex, Inc.\Plex Media Server\LocalAppDataPath
And if so, what’s it’s value?
I was looking at the wrong user here is the correct logs
Plex Media Server Logs_2022-02-03_07-49-36.zip (1.6 MB)
First of all, from your log:
Error parsing allowedNetworks '10.0.0.1 255.2552.255.0': Invalid Netmask 255.2552.255.0
If you want to allow the host on 10.0.0.1then enter: 10.0.0.1/255.255.255.255
Secondly, and worse, you have a broken database!
Feb 03, 2022 07:38:04.903 [2804] INFO - SQLITE3:0x912be90, 283, recovered 935 frames from WAL file C:\Users\2012R2\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.db-wal
Feb 03, 2022 07:38:04.903 [2804] ERROR - SQLITE3:0x912be90, 11, database corruption at line 67183 of [1b256d97b5]
Feb 03, 2022 07:38:04.903 [2804] ERROR - SQLITE3:0x912be90, 11, statement aborts at 10: [] database disk image is malformed
Feb 03, 2022 07:38:04.903 [2804] ERROR - SQLITE3:0x912be90, 11, database disk image is malformed in "PRAGMA cache_size=2000"
And lastly, you have an issue accessing a remote share
Feb 03, 2022 07:38:43.803 [3064] ERROR - Couldn't check for the existence of file "\\familyroom\C$\Users\jeremy.brown\AppData\Local\Plex\Plex Media Server\Sync\.grab": boost::filesystem::status: The user name or password is incorrect: "\\familyroom\C$\Users\jeremy.brown\AppData\Local\Plex\Plex Media Server\Sync\.grab"
Thanks for this info but how do I fix reconnect the HDhomeRun?
Heh, forgot the link to DB Repair, sorry
Ref: Repair a Corrupted Database | Plex Support
Plex Media Server Logs_2022-02-08_16-39-03.zip (4.9 MB)
I did what it said and still can not add live tv
Your database is sadly still not working
From your log:
Feb 08, 2022 16:36:38.094 [5824] ERROR - SQLITE3:0xe865e121, 11, database disk image is malformed in "PRAGMA cache_size=2000"
You are welcome to DM me your database, and I’ll take a look
See: Troubleshooting | Plex Support on how to download it
Okay, I’ve DM’ed you a download link for a fixed database
You should now do this:
Shut down PMS
Go to the directory named C:\Users\YOUR_USER_NAME\AppData\Local\Plex Media Server\Plug-in Support\Databases
In there, make a new directory named DBBak
move the following files into DBBak if they exists
  • com.plexapp.plugins.library.db
  • com.plexapp.plugins.library.db-shm
  • com.plexapp.plugins.library.db-wal
Also move all files starting with tv.plex.providers.epg into DBBak
Then copy the com.plexapp.plugins.library.db you got from me into
the directory C:\Users\YOUR_USER_NAME\AppData\Local\Plex Media Server\Plug-in Support\Databases`
Then start Plex again, wait 5 min, and check if you now can add a DVR
That resolved the issue thanks
