Anyone have one of the original HDHomeRun DUAL 101A2C68 and have it working with PLEX yet?
Before I start the process of buying an OTA antenna and hooking everything up I wanted to find out if anyone has had any luck yet? From all I have searched and read here most have given up and had to purchase a newer model to get it to work. I am in Jardín Antioquía Colombia so I would really only be able to get 6 channels here so not really worth the cost of a new box and getting it down to me here in Colombia so thus the post.
Thanks for feedback from anyone with this older tuner.
I have an old HDHomeRun Dual and it is network connected by managed by the Plex Tuner Service process which is part of Plex Media Server. I just use it for testing and it does work.
It identifies itself as HDHR3-EU for me (European version)
You can send this request to the device IP address in a browser and get the device details
Is there a way to try it with out having to buy an HDTV outdoor antenna and running a coax cable to it as I am in the middle of the Andes mountains and signal can only be had here with an antenna mounted high up on my second story roof and would be a pain to go through the hassle and money just for it not to work.
How good the signal level / quality for tuning the channels
How well the device operates with Plex Media Server
For the latter - you could take the device and a laptop to try Plex Media Server to someone you know in an area with good OTA reception and has an antenna and try it out there
For the signal level / quality and tuning channels, you will not know until you try it in your location
Thank you for the heads up! Just gave it a test drive on my Laptop and my Shield TV and for the most part it works. I get 71 free channels, only 2 are in español… AFV Espanol, which is mostly English with español subtitles and the other is Latin X Pop for music. The other 69 Channels do not have options for subtitles. Any plans for future updates to add more español channels or subtitles in español?
