HDHomerun found, channel scan failed
I’m trying to set up the DVR and live TV.
Plex will detect the HDhomerun without any problems but when I scan for channels it fails and tells me to check that the antenna in hooked up and getting a signal.
I use the same hardware to get live TV and DVR with WMC and Xbox so I know it has a signal.
Any thoughts?
Make sure you have the latest firmware on the HDHR. Old firmware is often the cause.
I went from the latest official FW to the current beta.
No luck. I have a ticket open with SD.
Can you do a Channel Scan via the Web interface for the HD HomeRun? Also, make sure your WMC and XBox don’t have the device in use while doing the Channel Scan (maybe unplug them temporarily).
The web interface for the HDHR can’t detect any channels. That is the strange thing as WMC and Xbox work perfectly.
I have the same issue with an avermedia volar hybrid q usb.
Detects it, asks me to scan. Hit cable scan and it actually does a (useless) scan. But if i leave the proper antenna selected and hit scan it gets to 0%, sits for 10 seconds then dumps out to an error. I’ll attach a pic.
Once this happens plex must be crashed/exited and reloaded before it will “find” the dongle again. If i just try a 2nd scan it will not initiate it (after switching cable/antenna as well).
The oem sw package (newest dl) is goofy but it did proper scans and spit back 50-60 channels (I’ve got a few that like to hide, apparently).
Plex appears to be asking the volar to or for something it don’t like, causing it to crap. I do not feel like diving into the hell that are the plex logfiles to verify this - it’s obviously borked atm tho.
Fresh cap card install
w10 x64
nvidia updated
plex pass and the qam nightly from the sticky tried
Posting the screenshot is not cooperating. Just a generic error saying scan failed to find anything. Do a dance and try again.
