HDhomerun guide channel mapping missing, needs manual entry which is most annoying
i have 2 HD home runs and the channel mapping works on one but not on the other
interesting that it does map some channles 63 as i manually mapped some in all rather than 150 on the working one
but cant record in HD as it wont see any channels
plex on Windows server standard (not beta)
no-one?
is there a way to reset the channel guide, the reason i ask is that i remove the DVR settings and re enable these bring up the same number of channels?
still no-one?
so does anyone else use 2 hdhomeruns, if so so the channels work ok on both as the ones i have the second tunes only shows about 50 channels and if its on the guide gets screwed, not that its much use but for instance i know f1 is on this weekend in the uk on channel 4 but with both tuners on i cant see it remove the second tuner and it shows up and is set to record.
i have a tbs tuner in the same Plex server but this is not supported or configured
Hi there. That’s a known issue with using 2 HDHR tuners that appeared in a recent version. You should, however, still be able to use a single tuner. We have an internal ticket open and engineering is looking into it.
ok
of the same make or just 2 in general?
It’s not limited to HDHR. We’ve reproduced it on other brands as well. Engineering is working on it.
is this fixed yet?
anyone is this fixed yet!!!
