I have a HDHR Connect Duo (HDHR5-2US) and when I was trying to watch something while recording something else I got the error ‘Unable to tune channel (No parts)’. I tried debugging it a bit and it turns out that with no recordings, if I watch 1 stream it works fine, but if I open another stream in another tab I got the same error. The HDHR status page shows that Tuner 2 isn’t being used at all when Plex was trying to tune the 2nd page. I then opened up the HDHR app on top of the first Plex stream and it works fine, and the HDHR status page shows that both tuners are being used. So for some reason Plex isn’t seeing the 2nd tuner.
Is this a bug that only lets you watch 1 stream even if you have 2 tuners? If so, how do I fix this?
