HDHomerun No Guide Data
Server Version#: 1.18.0.1913
Have Plex serverver running on a QNAP TS-453A serving to Fire TV and Nviia Shield I have not been able to use live TV for some weeks now because there is no guide data. I have tried the following:
Optimize Database
Clean Bundles
Empty Trash
Restarted server
Reinstalled HDHomerun
but when I get to entering postcode to get guyide data nothing happens. If I cancel out of this the HDHomerun isnt installed. I am vaguely aware something was changed regarding guide data some time ago and that has served only to break it for me.
Main reason to buy a Plex Pass was for this so desperate to get it fixed. Hope someone can help,
What Post Code?
Hopefully not somewhere in Australia.
Sames issue started today. Running version 1.18.1.1973 with HDHomeRun. Previously today I was able to view the guide, now nothing is displayed there… Confirmed the HDHomeRun is working normally when using its own app…
Live TV and the ability to record is now broken.
Same issue here with current release. I also noticed maxed out CPU usage while the plex media serer log is spamming
Nov 02, 2019 20:08:35.067 [0x812020100] DEBUG - EPG[cloud]: Next thing to start/end is at 2019-11-03 01:30:00 GMT (in -2314 seconds)
Nov 02, 2019 20:08:35.084 [0x812020100] DEBUG - EPG[cloud]: Next thing to start/end is at 2019-11-03 01:30:00 GMT (in -2314 seconds)
Nov 02, 2019 20:08:35.101 [0x812020100] DEBUG - EPG[cloud]: Next thing to start/end is at 2019-11-03 01:30:00 GMT (in -2314 seconds)
Nov 02, 2019 20:08:35.118 [0x812020100] DEBUG - EPG[cloud]: Next thing to start/end is at 2019-11-03 01:30:00 GMT (in -2314 seconds)
Nov 02, 2019 20:08:35.135 [0x80ea55f00] DEBUG - EPG[cloud]: Next thing to start/end is at 2019-11-03 01:30:00 GMT (in -2314 seconds)
Nov 02, 2019 20:08:35.151 [0x80ea55f00] DEBUG - EPG[cloud]: Next thing to start/end is at 2019-11-03 01:30:00 GMT (in -2314 seconds)
Nov 02, 2019 20:08:35.168 [0x80ea55f00] DEBUG - EPG[cloud]: Next thing to start/end is at 2019-11-03 01:30:00 GMT (in -2314 seconds)
Looks like a bug plex had early last year. I had to delete the DVR for plex server to calm down.
ps: Freenas btw.
Deleted DVR did not help, at least initially.
Today the guide started working normally.
Perhaps the time change flipped the EPG out?
Same here - no guide data showing and says ‘unable to load channel mappings’.
I deleted DVR and when re-adding I can’t passed the step where you need to enter post code (I’m in UK). Hopefully someone from Plex sees this as it’s totally broken at the moment!
I adding the DVR function back in today and it seems to be working normally now.
