Server Version#:1.19.4.2935
Player Version#:8.2.1.18636 (1cc6ce64)
Player: Nvidia Shield 2019 Pro. Connected to latest and greatest HDMI cable.
This was not an issue few weeks back. Seems like one of the latest update broke it somehow.
Issue: If Nvidia Shield is set to “4k 59.940Hz” and you play a 4k HDR movie, the HDR color is washed out. Although the TV does goes into HDR mode, the tone mapping is off.
#### Test Condition 1:
Nvidia Shield : “4k 59.940Hz” “Dolby Vision and HDR10 Ready”
Plex: Refresh Rate Switching : On
Movie: Zootopia (23.976 Fps Movie)
Issue: HDR in TV turns on, but the colors are extremely washed out.
It works the first time after a reboot, but from the second time onwards the HDR is washed out.
Image:
Shield is set to 23.976 Hz.
^^This is the main issue.
Movie: Gemini Man ( 59.940Fps movie)
Issue: No issues. HDR is switched correctly and colors are popping.
Shield is set to 59.940 Hz.
#### Test Condition 2:
Plex: Refresh Rate Switching : Off
Issue: HDR in TV turns on, and colors are accurate.
But the Shield is still in 59.940 Hz. (Expected)
The Shield is still in 59.940 Hz. (Expected)
#### Test Condition 3:
Nvidia Shield : “4k 23.976 Hz” “Dolby Vision and HDR10 Ready”
Issue: No issues .HDR in TV turns on, and colors are popping and accurate.
^^This is the workaround for now^^
#### Test Condition 4:
Issue: HDR is switched correctly and colors are popping.
The Shield is still in 23.976 Hz. (Expected)
The issue is plex specific for sure. The same tests have been run on Kodi and Emby and they both are able to switch things correctly without washed up colors.
Please look into this issue. As it stands, the workaround is annoying and not noob-friendly. My GF also uses my system and it’s hard for me to tell her all the steps.
