Hellohue not working
Hi.
All I have used hellohue for at long time. But now out off the blue i dont work.
I tryed removing the plugin and download a New bundle but no luck.
I can see that it remembers the settings. Meaby a New sync with My hue bridge Will help? But how do I trick it?
I miss the feature.
Regards Daniel and thanks
https://forums.plex.tv/t/rel-hellohue-1-1-8-4-sync-and-control-your-philips-hue-lights-with-plex/122675
The Reader’s Digest Version:
Plugins are gone.
I know but meny ppl have this working. I cant get into the hole sync with hue bridge thing.
Near the bottom of that thread it is revealed the thing is belly up. <—and that’s where it ends.
If there are special tricks - you’ll have to find them elsewhere - or have the funeral.
To clear settings, and reverting to a brand new baby, take a peak here, where I outlined HowTo for another plugin named WebTools:
And as a followup, to gain access to the plugin menu, use Kitana
