Help, I had to reset my password now my server isn't working
Server Version#: 1.113.0.359-0d79a49f
<If providing server logs please do NOT turn on verbose logging, only debug logging should be enabled> reset my password off a new phone, and it locked me out of my library. Removed all authorized devices, and tried to long back in with no luck. Uninstalled plex, and the media server to reinstall the server, but it keeps me in a constant loop of wanting to install the server even though its all ready installed. How can I fix this?
If you opted to sign out all devices when you reset your account password, this includes your server.
This means you need to re-claim it, so apps signed into your account can find it.
To do that, open the local web app of your server:
Option 1: open http://127.0.0.1:32400/web in a browser on the same machine
Option 2: click the Open Plex option in the context menu of the PMS icon in the system tray.
Go to Settings > [Server Name] > General
Click the Sign In button at the center of that settings page
So I did all this on the same computer I ran the server, but it didnt help fix the problem. Im logged in, but once I click the your media button it just takes me to download the media server but I already have it installed
Are you using a browser to open the bundled web app locally?
Did you previously use Plex with a different account?
Im using the browser, and it’s opening up the app. I only have one account setup, so using the original account/com I used when setting up the server
