Help me please
Hello,
So I've installed Rasplex 0.4 rc4 on my SD-Card and put it into my Raspberry PI (model A). Then I could select my WLAN, etc. Now I came to a Screen where "Search" is written 10 times, but I cant click anywhere, I cant do anything. Also, I think my LG Magic Remote Control is not working correctly because everything I click in that window, It automatically selects the letter A....
What went wrong? Why am I on this stupid screen with no possibility to go back?
That's my remote control. I have SIMPLINK activated.
Do you have a plex server installed and running? I  have found I get that screen if for some reason the plexht is not able to find your plex server.
As for the remote, I don't know but looking at the info on Amazon about it, it seems that it acts like a mouse and Plex Home Theater is not mouse enabled and only allows keyboard commands.
EDIT: I see that SIMPLINK is using CEC commands to the Pi.  I have no background on this.
That being said, I personally don't use a "remote" for my PHT and just use the Android app to push the show I want to watch on the PI.
Hello,
RasPlex 0.4 rc4 works on a model A?  I was under the impression that the lack of memory made this almost impossible?
Um yeah sorry I meant model B of course....
And I have found the solution. I must not use the "mouse" pointer but the 4 arrow keys in the middle of the remote. Thank you
I had this issue when my server was having problems.  restarted my server and issue went away.
