HELP plex keeps stopping playback!!!!
I paid for the app but haven’t upgraded the service, I find it funny that the closer you get to the end of the movie the more buffering and delays you face. This is most likely plex’s way of annoying users into upgrading the service. Well you’ve lost me as a customer, if I can’t watch for free to check the system how do you expect a valued customer when you provide such a ■■■■ service. I can’t watch a movie without more than 20 buffering breaks which is super annoying. Good bye plex I’d rather pay for Netflix.
Hi there.
Had this issue also and every 20mins bang the server unavailable or video cannot be played. Every 20 mins on schedule it would do so.
I had a look around the forums and nothing, windows forums nothing and Xbox forums nothing. I had a look around the Xbox and Web apps and nothing.
Checked my Internet connection (ethernet) all fine so I checked on my power plan all was OK so I went into advanced power options (windows 10) works for all Windows versions 7 and up scrolled to “Turn Hard Drive Off” and low and behold it was set to 20 mins the exact same time frame plex went off so I set it to Never (you need to press the down arrow to get to never) then I applied and closed the window and it seems to be working better now no stops working seamlessly.
Hope this works Éire
