Help recovering titles / lists of my disappeared movies!
Hi everyone.
I run PMS on a dedicated Windows 7 PC that I built a few years ago.
Yes, I know, I’m very badly overdue for an upgrade……like, horribly so. I get it.
The situation I’m writing about here is part of what’s forcing me to finally make the jump to a new box.
That said, I recently noticed that some of my movies (downloaded from internet) that I knew I had - because I’d watched them many times - disappeared from my Plex.
Upon further investigation, I realized that about HALF of my 3,000 movies were gone.
Disappeared from my Plex library. :-0
Further investigation reveals the Hard Drive that about half (maybe 1/3) of my library was stored on, was failing / reallocated sectors & such.
What’s really weird; most of my movies are kept in folders titled for the film.
For example; “The Hangover” movie would be stored as follows:
FOLDER: “The Hangover [2009] 1080p BluRay 5.1”
FILE INSIDE THE FOLDER: “The Hangover [2009] 1080p BluRay 5.1.mp4 (.mkv)”
Any associated .nfo, .srt cover art, (or folders with multiple subtitle files) would also be stored inside the folder, of course.
It appears most - if not all - of the movies that were stored “loose” i.e.; just in the root “MOVIES” directory; most of those are gone.
For movies like “The Hangover” example above that were in their own subfolders; only the .mp4 / .mkv file is gone; the folder still remains, as well as any .srt files, .nfo, .jpg cover art; any other sub-folders or files are STILL THERE. Just the video file; whether .mkv or .mp4 or whatever; that is the only thing that’s missing.
First off; has anyone ever heard of this? If I didn’t know better (maybe I don’t) it sounds like some sort of a virus / hack / malicious actor that deleted half of my movies.
How can the movie FILES disappear, but not the other items in their folders?
Adding insult to injury, I have discovered that - for some very dumb reason - my backups are mirror images of the active directories. I’m still trying to figure out if I incorrectly configured something or what, (obviously I did) but basically; out of ~1500 of the movies that are missing from my Plex, about another 1/2 or 1/3 of those are not backed up anywhere.
Needless to say, I’ve already taken steps to permanently fix that problem.
They’re just movies I’ve downloaded from the internet and 100% replaceable, so I’m not THAT broken up about it, but still… it sucks. I’ve put a lot of time into collecting, labeling, curating my movie collection…
I’ve now quadruple-checked that any & all of my other data is absolutely backed up via multiple methods……
The main question is;
Is there any way I can use Plex to help find out exactly what files are missing / deleted from my Plex?
I already downloaded server logs & it’s nice to see Plex keeps such detailed logs, and for so long. I’m seeing logs going back years.
One big problem is; this has taken place over a long time. At least a few months or more. Obviously I don’t fuss with my movies too much; there are movie files I’ve tossed into my Plex & left there 10 years ago.
Because I don’t have as much time as I’d like to watch movies, I didn’t notice the missing files for months, maybe close to or at a year.
Is there any way I can use Plex logs or any other ideas you guys have to discover even some of what movie files went missing?
Hope this all makes sense and Thanks
First, go to Settings → Library and, if enabled, deselect “Empty trash automatically after every scan.”
Second, do not empty trash manually.
You can use WebTools-NG’s Find Media capability. It compares the list of files on the drive to what is in the database.
GitHub Home Page: GitHub - WebTools-NG/WebTools-NG: WebTools Next Generation for Plex
Download: On the right hand side of the home page, under Releases, select “Latest” (currently 1.2.1)
Find Media section of Wiki: Find Media · WebTools-NG/WebTools-NG Wiki · GitHub
Note: If the information has already been removed from the database, you can try loading a backup. See Restore a Database Backed Up via ‘Scheduled Tasks’.
I forget what prompted me to do that, but I did recently DISABLE “Empty Trash automatically”
And Thanks for the tool - that’s awesome! Sounds like exactly what I need!
I do believe I have older backups of my Plex program directory / database, so hopefully I could point the tool to that??
I haven’t looked yet but are there pretty good instructions on how to use that WebTools app?
Most stuff on Github is…targeted to people who are comfortable with the command line, minimal GUI, etc.
This sounds promising, so thank you again so much!!
No. You load the backup into Plex Media Server, then run the tool. See the Restore a Database… document.
Ah ok. Is there any reason I couldn’t do this inside a VM or a separate PC - other than my actual live Plex Server?
I will read the documentation before asking any more questions though. :slight_smile:
Again; I’m super grateful for the help…
You can run WebTools-NG on a separate system.
It has to be on the same network as PMS, so it can query the database.
It also needs access to the media files, so it can compare the database to the file system.
If you run WebTools on a different system, you will have to enable Windows file sharing on the PMS system, then mount the shared directories (map a network drive) on the system running WebTools.
Example:
I have PMS running on a Synology NAS, where the media files are stored. The files are also shared via SMB, so I can access them from my Windows 10 desktop.
My Windows 10 desktop has the Synology mapped to the O:\ drive.
I run WebTools on my Windows desktop.
In WebTools → Global Settings → Library Mapping, I map the Plex libraries to the appropriate directory path (eg: Movies maps to O:\movies).
In WebTools → Plex Media Server → Find Media, I pick the desired Library, and click “Run.”
WebTools then compares entries in the Plex Media Server database to what it fines in the file system and generates a report. The report is saved as a .csv file.
The webtools needs an active running server to ping off of. It does not just open up the plex database file and retrieve the list of contents in the database. Instead, a program like Plex must run and respond to the queries from the webtools program.
If you want to “clone” your server, you can do so. Use the “move” steps in the following article: https://support.plex.tv/articles/201370363-move-an-install-to-another-system/
This way, you can run the older backup of your database on a server that isn’t your current active one.
