HELP: Rips in Format ".m2ts" are "UNAVAILABLE"
Dear Plex-Support-Team, dear community,
My Movies are nearly all 95% in the format “.m2ts” (around 8TB of Data).
Sadly Plex does not play them and shows the status “unavailable”.
Wierdly all other media-data is displayed (resolution, duration, bitrate etc.)…
What can I do?
Converting them into mkv is NOT an option.
I certainly do NOT have that time. This would take months over months…
Will I have to refund my purchase?!?
Thanks in advance for advice & help!
Best Regards,
Melvin
PS:
I’m on a Mac.
Movies are on my NAS (Drobo Gen 2) in format .m2ts [nearly 8TB]
Want to Stream on my iDevices (iPad, iPhone etc.)
Follow-Up.
Wierdly, if I remux them with tsmuxer into a new m2ts-file (No Chapters) they seem to load…
I’ll check up on that.
Glad you figured it out. I was going to suggest doing what you did as some programs write funky headers.
I use m2ts for my MVC files and keep others in mp4. But both work just fine in Plex for me.
