I have a brand new Sony X750H Android TV. I downloaded the Plex player from the Google Play store. It is getting data from my Synology NAS.
I have MKV files taken from DVD. Most won’t play at all - the audio plays (and subtitles) but the video just freezes at the first frame. The Playback Info says it is Direct Play, 720x480, MKV, and MPEG2VIDEO with the ExoPlayer player.
Interestingly, it will play files take from Blu-Ray which are being transcoded. For those, it says “Unable to Direct Play as VC1 is not supported on this device”
I have an Amazon Fire stick in my other TV (older Vizio). It plays everything. The Playback Info is the same.
I need help debugging this. This is the TV my wife and I watch the most and she won’t be happy if I have to use a Fire stick (me neither). What is wrong with this Sony? It is the exact same Android Player that is on the Fire Stick. I feel like there is some problem or setting with the Sony but I can’t find it.
Thanks for any hints - I’ve tried a bunch of settings. I don’t know how to provide logs but I’'m not sure they would say anything if the problem is on the player?
Server Version#:1.21.1.3876-3c3adfcb4
Player Version#: 8.11.0.22186
Info on how to get Android TV app logs can be found here https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/#toc-1
I’ve never used a Sony so not sure if there is any setting for that sorta thing on itself. if it was direct play the app thinks it is fine for that TV. or I should say the TV is saying that mpg2video is supported.
You can force it to transcode by lowering quality a bit. or turn on auto adjust quality sometimes will if it is questionable
Thanks! I’ll look for the logs. I’ve found that once the video is playing (stuck) if I go into playback controls, change the quality down, then change it back to auto adjust it will play (and even looks nicer). I need to make it do this automatically so I don’t have to do it every time.
OK the problem seems to be something to do with the quality settings. The TV is at home with the server. If I leave the Home Streaming setting to max, or anything above 4 Mbps, the video will not play. Is this setting a maximum?
Here is the first part of the log:
01-14 22:53:41.866 i: [MediaDecisionEngine] Server was happy with client’s original decision
01-14 22:53:41.867 i: [MediaDecisionEngine] Decision: CanPlay: true CanDirectPlay: false CanDirectStreamVideo: false CanDirectStreamAudio: false CanDirectPlaySubtitle: false CanTranscodeSubtitle: false CanDisplayVideo: true Transcode Reason: Direct play is disabled via ‘Convert automatically’ preference
01-14 22:53:41.868 i: [LoadControl] New bitrate: 200000, Maximum: 200000
01-14 22:53:41.869 i: [MediaDecisionMediaSource] Using FFMediaSource
01-14 22:53:41.871 i: [video] User maximum h264 profile determined: 51
01-14 22:53:41.872 i: [video] Device recommended h264 profile determined: 51
01-14 22:53:41.873 i: [video] Segmented MKV not supported
01-14 22:53:41.887 i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
01-14 22:53:41.888 i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 512
01-14 22:53:41.889 i: [BufferHelper] Segment count: 3276
01-14 22:53:41.892 i: [MediaDecisionMediaSource] onMediaDecisionRefreshed (Sources: 1)
01-14 22:53:41.895 i: [DisplayBehaviour] Mode found: 1920x1080 @ 60.0000Hz (1) (Score: 123.14 (RR: 49.94 R: 73.20)
01-14 22:53:41.896 i: [DisplayBehaviour] Best mode for 720x480 @ 29.969999Hz selected as 1920x1080 @ 60.0000Hz (1).
01-14 22:53:41.897 i: [DisplayBehaviour] Mode is already set to our best mode of 1920x1080 @ 60.0000Hz (1).
01-14 22:53:41.900 i: [video] User maximum h264 profile determined: 51
01-14 22:53:41.900 i: [video] Device recommended h264 profile determined: 51
01-14 22:53:41.902 i: [video] Segmented MKV not supported
01-14 22:53:41.918 i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
01-14 22:53:41.919 i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 512
01-14 22:53:41.919 i: [BufferHelper] Segment count: 3276
01-14 22:53:41.925 i: [video] User maximum h264 profile determined: 51
01-14 22:53:41.925 i: [video] Device recommended h264 profile determined: 51
01-14 22:53:41.928 i: [video] Segmented MKV not supported
01-14 22:53:41.941 i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
01-14 22:53:41.942 i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 512
01-14 22:53:41.945 i: [BufferHelper] Segment count: 3276
01-14 22:53:41.951 i: [FF] Creating context for playback.
01-14 22:53:41.952 i: [ExoPlayer][EventLogger] timelineChanged [18.32, 15.57, window=0, periodCount=1, windowCount=1, reason=DYNAMIC
01-14 22:53:41.952 i: [FFmpeg] [INFO] Demuxer pipeline terminated.
01-14 22:53:41.952 i: [ExoPlayer][EventLogger] period [?]
01-14 22:53:41.952 i: [FFmpeg] [INFO] Demuxer has been successfully closed.
01-14 22:53:41.952 i: [FF] Setting additional option: tls_verify: 1
01-14 22:53:41.952 i: [ExoPlayer][EventLogger] window [?, false, false]
01-14 22:53:41.952 i: [FFmpeg] [INFO] Adding option: ignore_chapters 1
01-14 22:53:41.952 i: [ExoPlayer][EventLogger] ]
01-14 22:53:41.953 i: [FF] Setting additional option: resolve_hosts: 192-168-1-100.ffcaaa9c865e43dd8acee57144f0fffd.plex.direct:192.168.1.100
01-14 22:53:41.953 i: [FFmpeg] [INFO] Adding option: live_start_index 0
01-14 22:53:41.953 i: [Player][ExoPlayer] onTimelineChanged (Position: 15573 ms)
01-14 22:53:41.953 i: [FFmpeg] [INFO] Adding option: reconnect 1
01-14 22:53:41.953 i: [FFmpeg] [INFO] Adding option: tls_verify 1
01-14 22:53:41.953 i: [FFmpeg] [INFO] Adding option: resolve_hosts 192-168-1-100.ffcaaa9c865e43dd8acee57144f0fffd.plex.direct:192.168.1.100
01-14 22:53:41.953 i: [FF] Opening https://192-168-1-100.ffcaaa9c865e43dd8acee57144f0fffd.plex.direct:32400/video/:/transcode/universal/start.m3u8?audioBoost=100&autoAdjustQuality=1&directPlay=0&directStream=0&directStreamAudio=0&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F1058&protocol=hls&session=bcc17752a46eff94-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160&X-Plex-Client-Identifier=bcc17752a46eff94-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain|main%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084|bt709|bt470m|smpte240m|smpte170m|bt470bg|bt2020-10%26isRequired%3Dfalse)&X-Plex-Device=BRAVIA%20VU1&X-Plex-Platform=Android&X-Plex-Platform-Version=9&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Token=...LFM1&X-Plex-Version=8.11.0.22186 .
01-14 22:53:41.953 i: [FFmpeg] [INFO] Allocating format context.
01-14 22:53:41.955 i: [FFmpeg] [INFO] Opening input from https://192-168-1-100.ffcaaa9c865e43dd8acee57144f0fffd.plex.direct:32400/video/:/transcode/universal/start.m3u8?audioBoost=100&autoAdjustQuality=1&directPlay=0&directStream=0&directStreamAudio=0&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F1058&protocol=hls&session=bcc17752a46eff94-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160&X-Plex-Client-Identifier=bcc17752a46eff94-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain|main%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084|bt709|bt470m|smpte240m|smpte170m|bt470bg|bt2020-10%26isRequired%3Dfalse)&X-Plex-Device=BRAVIA%20VU1&X-Plex-Platform=Android&X-Plex-Platform-Version=9&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Token=...LFM1&X-Plex-Version=8.11.0.22186 .
01-14 22:53:41.958 i: [FFmpeg] [INFO] [Cache] Close requested, terminating.
01-14 22:53:41.961 i: [FFmpeg] [INFO] [Cache] Opening source from https://192-168-1-100.ffcaaa9c865e43dd8acee57144f0fffd.plex.direct:32400/video/:/transcode/universal/start.m3u8?audioBoost=100&autoAdjustQuality=1&directPlay=0&directStream=0&directStreamAudio=0&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F1058&protocol=hls&session=bcc17752a46eff94-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160&X-Plex-Client-Identifier=bcc17752a46eff94-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain|main%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084|bt709|bt470m|smpte240m|smpte170m|bt470bg|bt2020-10%26isRequired%3Dfalse)&X-Plex-Device=BRAVIA%20VU1&X-Plex-Platform=Android&X-Plex-Platform-Version=9&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Token=...LFM1&X-Plex-Version=8.11.0.22186 .
01-14 22:53:42.232 i: [FFmpeg] [INFO] [Cache] Cache is not enabled, connecting source context instead.
01-14 22:53:42.236 i: [FFmpeg] [INFO] [hls @ 0x7e296e00] Opening ‘https://192-168-1-100.ffcaaa9c865e43dd8acee57144f0fffd.plex.direct:32400/video/:/transcode/universal/session/bcc17752a46eff94-com-plexapp-android/base/index.m3u8 ’ for reading
01-14 22:53:42.596 i: [FFmpeg] [INFO] [hls @ 0x7e296e00] Opening ‘https://192-168-1-100.ffcaaa9c865e43dd8acee57144f0fffd.plex.direct:32400/video/:/transcode/universal/session/bcc17752a46eff94-com-plexapp-android/base/00000.ts ’ for reading
01-14 22:53:43.076 i: [FFmpeg] [INFO] [hls @ 0x7e296e00] Opening ‘https://192-168-1-100.ffcaaa9c865e43dd8acee57144f0fffd.plex.direct:32400/video/:/transcode/universal/session/bcc17752a46eff94-com-plexapp-android/base/00001.ts ’ for reading
01-14 22:53:43.668 i: [FFmpeg] [WARN] [NULL @ 0x686afc00] ignoring invalid SAR: 11160/11173
01-14 22:53:43.684 i: [FFmpeg] [INFO] Successfully opened https://192-168-1-100.ffcaaa9c865e43dd8acee57144f0fffd.plex.direct:32400/video/:/transcode/universal/start.m3u8?audioBoost=100&autoAdjustQuality=1&directPlay=0&directStream=0&directStreamAudio=0&fastSeek=1&hasMDE=1&location=lan&maxVideoBitrate=200000&mediaBufferSize=209664&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F1058&protocol=hls&session=bcc17752a46eff94-com-plexapp-android&subtitleSize=100&videoBitrate=200000&videoQuality=100&videoResolution=3840x2160&X-Plex-Client-Identifier=bcc17752a46eff94-com-plexapp-android&X-Plex-Client-Platform=Android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain|main%2010)%2Badd-limitation(scope%3DvideoTranscodeTarget%26scopeName%3Dhevc%26scopeType%3DvideoCodec%26context%3Dstreaming%26protocol%3Dhls%26type%3Dmatch%26name%3Dvideo.colorTrc%26list%3Dsmpte2084|bt709|bt470m|smpte240m|smpte170m|bt470bg|bt2020-10%26isRequired%3Dfalse)&X-Plex-Device=BRAVIA%20VU1&X-Plex-Platform=Android&X-Plex-Platform-Version=9&X-Plex-Product=Plex%20for%20Android%20(TV)&X-Plex-Token=...LFM1&X-Plex-Version=8.11.0.22186 , finding 2 streams.
01-14 22:53:43.684 w: [FF] AVC configuration parser failed, falling back to using the original initialisation data.
01-14 22:53:43.685 i: [VideoStream] Dolby Vision is unsupported on this display or device.
01-14 22:53:43.685 i: [FFmpeg] [INFO] Input #0 , hls, from ‘’:
01-14 22:53:43.687 i: [FFmpeg] [INFO] Duration:
01-14 22:53:43.688 i: [FF] Container[hls] No Title - 0 kbps, 1 hr 37 min [CT: 0us, ST: 10061400us, SRT: -9223372036854775808us].
01-14 22:53:43.692 i: [FFmpeg] [INFO] 01:37:49.00
01-14 22:53:43.692 i: [FFmpeg] [INFO] , start:
01-14 22:53:43.693 i: [FFmpeg] [INFO] 10.061400
01-14 22:53:43.693 i: [FF] VideoStream[0-h264] 854x480 [SAR 1:1, DAR 854:480]. H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 - Unknown Profile (video/avc), 8.1 Mbps -54 sec 29.97fps, No Title / Unknown (null), 1 / 39 bytes, .
01-14 22:53:43.694 i: [FFmpeg] [INFO] , bitrate:
01-14 22:53:43.694 i: [FFmpeg] [INFO] N/A
01-14 22:53:43.695 i: [FFmpeg] [INFO] Program 0
01-14 22:53:43.696 i: [FF] AudioStream[1-ac3] 6 channels over 1551 (5.1(side)), 48000 Hz, 0,0 padding. ATSC A/52A (AC-3) - Unknown Profile (audio/ac3), 8.1 Mbps -54 sec 0.00fps, No Title / English (eng), 0 bytes, .
01-14 22:53:43.697 i: [FFmpeg] [INFO] Metadata:
01-14 22:53:43.700 i: [FF] Video decoder doesn’t support ac3 (audio/ac3).
01-14 22:53:43.701 i: [FF] Audio decoder supports ac3 (audio/ac3).
01-14 22:53:43.702 i: [FF] Video decoder doesn’t support h264 (video/avc).
01-14 22:53:43.702 i: [FFmpeg] [INFO] variant_bitrate :
01-14 22:53:43.704 i: [FFmpeg] [INFO] 8064000
01-14 22:53:43.705 i: [FF][MediaPeriod] Selecting tracks.
01-14 22:53:43.705 i: [FFmpeg] [INFO]
01-14 22:53:43.706 i: [FF] Seeking outside buffer
01-14 22:53:43.708 i: [LoadControl] Assumed Bitrate: 400000, Segment Count: 46875
01-14 22:53:43.709 i: [FFmpeg] [INFO] Stream #0:0
01-14 22:53:43.710 i: [LoadControl] Detected memory pressure, reducing segment count to fit available memory: 512 MB
01-14 22:53:43.711 i: [LoadControl] Final Segment count: 1638 (102 MB / 4 Seconds)
01-14 22:53:43.711 i: [FFmpeg] [INFO] : Video: h264 (Main) ([27][0][0][0] / 0x001B), none(progressive), 854x480
01-14 22:53:43.715 i: [ExoPlayer][EventLogger] decoderEnabled [20.09, 15.57, window=0, video]
01-14 22:53:43.715 i: [ExoPlayer][EventLogger] decoderEnabled [20.09, 15.57, window=0, audio]
01-14 22:53:43.717 i: [FFmpeg] [INFO] ,
01-14 22:53:43.717 i: [ExoPlayer][EventLogger] tracksChanged [20.09, 15.57, window=0,
01-14 22:53:43.717 i: [FFmpeg] [INFO] 29.97 fps,
01-14 22:53:43.717 i: [FFmpeg] [INFO] 29.97 tbr,
01-14 22:53:43.717 i: [ExoPlayer][EventLogger] Renderer:1 [
01-14 22:53:43.717 i: [FFmpeg] [INFO] 90k tbn,
01-14 22:53:43.718 i: [ExoPlayer][EventLogger] Group:0, adaptive_supported=N/A [
01-14 22:53:43.718 e: [FF] Decoder failed to read format from input.
01-14 22:53:43.718 i: [FF] Loading canceled (released: false)
01-14 22:53:43.718 i: [ExoPlayer][EventLogger] Track:0, id=0, mimeType=video/avc, bitrate=8064000, codecs=h264, res=854x480, fps=29.97003, supported=YES
01-14 22:53:43.721 i: [FFmpeg] [INFO] 90k tbc
01-14 22:53:43.721 i: [FF] Input has been seeked to 15573000us.
01-14 22:53:43.721 i: [ExoPlayer][EventLogger] ]
01-14 22:53:43.722 i: [FFmpeg] [INFO] Metadata:
01-14 22:53:43.722 i: [ExoPlayer][EventLogger] Metadata [
01-14 22:53:43.722 i: [FFmpeg] [INFO] variant_bitrate :
01-14 22:53:43.722 i: [FFmpeg] [INFO] 8064000
01-14 22:53:43.722 i: [ExoPlayer][EventLogger] original_init_data: (Value: 0 Buffer: 39 bytes)
01-14 22:53:43.722 i: [ExoPlayer][EventLogger] scantype_progressive: (Value: 1 Buffer: 0 bytes)
01-14 22:53:43.723 i: [ExoPlayer][EventLogger] ]
01-14 22:53:43.724 i: [ExoPlayer][EventLogger] ]
01-14 22:53:43.725 i: [ExoPlayer][EventLogger] Renderer:2 [
01-14 22:53:43.726 i: [FFmpeg] [INFO]
01-14 22:53:43.726 i: [ExoPlayer][EventLogger] Group:0, adaptive_supported=N/A [
01-14 22:53:43.728 i: [FFmpeg] [INFO] Stream #0:1
01-14 22:53:43.730 i: [FFmpeg] [INFO] (eng)
01-14 22:53:43.731 i: [ExoPlayer][EventLogger] Track:0, id=1, mimeType=audio/ac3, bitrate=8064000, codecs=ac3, channels=6, sample_rate=48000, language=eng, supported=YES
01-14 22:53:43.732 i: [ExoPlayer][EventLogger] ]
01-14 22:53:43.737 i: [ExoPlayer][EventLogger] Metadata [
01-14 22:53:43.737 i: [FFmpeg] [INFO] : Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, 5.1(side), fltp, 640 kb/s
01-14 22:53:43.737 i: [ExoPlayer][EventLogger] block_align: (Value: 0 Buffer: 0 bytes)
01-14 22:53:43.738 i: [FFmpeg] [INFO] Metadata:
01-14 22:53:43.738 i: [ExoPlayer][EventLogger] channel_layout: (Value: 1551 Buffer: 0 bytes)
01-14 22:53:43.739 i: [FFmpeg] [INFO] variant_bitrate :
01-14 22:53:43.739 i: [ExoPlayer][EventLogger] original_init_data: (Value: 0 Buffer: 0 bytes)
01-14 22:53:43.739 i: [FFmpeg] [INFO] 8064000
01-14 22:53:43.739 i: [ExoPlayer][EventLogger] ]
01-14 22:53:43.740 i: [FFmpeg] [INFO]
Please Please can someone help me? This problem is not going away. Can anyone point me in the right direction? The video freezes on the first frame when I direct play a simple DVD MKV file. This works on my other TV (Firestick) and iOS apps, and happens on every video. The only way I can play is to set the Home streaming to 3 or even 2 Mbps, or below. The NAS and TVs are on a wired ethernet. I think the problem is with this new Sony TV
The Sony TV is android TV, a Bravia X750 model.
The TV is running Plex for Android 8.11.0.22186
The Plex Media Server is on a Synology NAS 1.21.2.3943-a91458577
Here is a copy of the log from the TV: sonyplexfail.txt (1.2 MB)
system
Closed
May 3, 2021, 4:40am
6
