Delete plug-ins bundles (they will get re-downloaded to latest versions when you restart) - located in /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/
Restart plex - /etc/init.d/plexmediaserver start
Refresh metadata - turboscan
When i try to acces Plug-ins folder and delete i get an error:
There are a couple things in your logs which are considered “noise” errors.
PMS does some opportunistic searching.
At the time your logs were captured, it was still in the middle of adding new media ( La Guerra de Caliban) episodes. PMS only works on one library section at a time.
Did all the television episodes update ok?
After the television was done, did you perhaps try a ‘refresh all metadata’ to make it search again?
If not, would you then grab the logs again as soon as it completes so I may see the deltas ?
With your consent, we’re going to hit it with a big hammer.
Stop Plex
open a terminal
sudo rm -rf "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Data/*"
Start Plex
Go to the section and refresh all metadata
What the above has done is forcibly clear the metadata cache & tokens used from the previous host. Now it will begin again , fresh, while existing metadata in the DB remains
