@trumpy81 said:
Another good choice if you do need HEVC and 4K is the Odroid C2. It is very similar to the Raspberry Pi 2/3 and it will handle HEVC/4K. It can also be taped to the back of the TV and the TV remote will operate it.
It also runs RasPlex/OpenPHT the same as the Raspberry Pi and the cost is much the same.
Other things to consider though, is to make sure your files are capable of direct playing on any device you happen to choose. That can save you a lot of headaches down the track.
Since you are likely to be streaming across the net to your parents house, try to maintain your files at 720p and keep the overall bitrates as low as possible.
With Plex, you can maintain very high quality files for local use and a low bitrate file for streaming and Plex in most cases will auto select which file to use without any intervention by you.
Simply store a high quality file and a file for streaming in the same folder with almost the same name.
EG:
Divergent (2014) 4K.mp4
Divergent (2014) 720p.mp4
Plex will ‘group’ those two files and display a number in a square at the top left corner of the poster so that you know there is more than one file in the group.
When someone plays that Movie, Plex will decide which file to use based on the client device and it’s location. So if your parents were to watch it, Plex would serve them the 720p version and if you were to watch it, you would be served the 4K version, assuming your Plex client could display that file of course.
Thanks for this information, hopefully you can enlighten me a bit further.
I will soon be returning home to stay with my parents, so bitrate is not really an issue (i would hope). As for my files they appear to be mostly MKV formats but some require transcoding when using an amazon FS but not for other files, which is unclear to me.
With the Odroid supporting HEVC i assume this would cover further formats/codecs? Also, is there somewhere in the UK that sells the device that you may know of?
Lastly looking at OpenPHT - what is it? I’ve tried to search it up and learn more but im unable to. I’ve saw and understand RasPlex though, but is OpenPHT you would use in combination of RasPlex or is it a different plex client?
