Help with TV Show Library
I got the Whose line is it anyways media (season 1), after converting it to a mp4 file, the library isn’t showing up in my server, can someone guide me as to why and what I can do to fix it and have more than one “tV Show in my TV Shows Library
The folder for another tv series I have is there, do I need separate folders for each move/series?
Series will go in a TV show folder, Movies go into a separate Movie Library.
Each series should go in it’s own folder under the toplevel TV Show folder.
This will explain it better.
https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/
For series, that should rather be https://support.plex.tv/articles/naming-and-organizing-your-tv-show-files/
