No idea, you can always drop in to safe mode and roll back if it doesn’t work.
Oh strange, you could try the other cab that’s the same version. Or maybe you need to be on that newer “Servicing update” of Server 2016, not sure how you get that.
Might need to install the latest servicing stack update (SSU) then a bunch of updates might just appear on windows update. Or that might require paying MS for the extended support as I think windows 2016 is publicly EOL
Maybe this Microsoft Update Catalog
Windows Server 2016’s mainstream support ended on January 11, 2022, but it will continue to receive extended support, including security updates, until January 12 2027, . After the mainstream support period, no new features or non-security updates will be provided.
But, yes, it appears a lot more would need to be modified than I would prefer to do just for this current situation (x265). Hopefully, Plex can come up with a solution instead.
I recommend Ubuntu Server, that’s what I’m using on my home server, everything works great ![]()
Hope to do so, but “life” is currently happening (illness, family, priorities, etc.) Thanks for your patience.
Does this build happen to address the issue?
Looks like you don’t accept private messages, so sent logs to Atomatth.
STOP the presses…I used the wrong build! Sorry, thought you wanted me to use the new beta. You sent me another build. I’ll try it!!!
Sorry, busy day. Son had wisdom teeth out this morning.
New logs sent to Atomatth
how about this build?
I should add, I’m testing only with the Roku (ultra - latest) now.
I restarted Plex before and after updating.
@Kilgry if you turn off HEVC transcoding does hw transcoding work? Looking theough your logs you appear to have a different error than everyone else. Did you try more than this one file?
