Hi all, i have two issues with my PLEX in a docker on UNRAID please help im struggling to fix
Hi i hope you can help i have two issues:
1, EDITED i fix the preroll issue
  1. I can only get it to connect remotely when its not a direct connection even after manually setting up a forwarding rule to “Destination IP WAN DHCP From Any Port 32400 Forward IP 192.168.1.81 Forward Port 32400 Protocol Both”, it is also on the same unraid docker image
thanks in advance!
bumppp
Does your ISP provide you a publicly routable IPv4? Many people still think that IPv4 addresses have not been exhausted.
sorry im not sure what you mean. i have sky fiber without a static IP as it wasn’t an option, thanks for the reply
Then call your ISP
