High Cpu use with subtitles
Hello
First of all. Great work with PlexConnect. Now I don't have to handbrake all MKVs to iTunes content anymore. Saving a lot of time and computer power.
Everything runs smoothly, but when I activate subtitles the fan go nuts after 5 min. or so. This only happens with MKVs and not Mp4/Mv4. When I look under "activity monitor" this "plex new transcoder" shows this WITHOUT subtitles.
![post-206401-0-10745900-1389529033.png|665x500](upload://5OuxYDYMjvj8rS7HncvGRDXqWG.png)
Then when i use subtitles I get these activities.
![post-206401-0-30001400-1389528972.png|673x500](upload://nkUEesVJgfRoIuERs3OOyBgE1KC.png)
How can CPU usage go from between 30-50 % to 300-350 % just because of use of subtitles.
When I run mv4 files this don't happened.
I need subtitles so what options do I have?
Are this going to be fixed?
What other options do I have?
My specs are
Macbook air mid 2012, with 1,8GHz i5
4 gb ram
Newest OS X
Apple TV 3
PMS 0.9.8.18.290
Latest PlexConnect
Thank you in advance for help
Without subtitles you most likely "direct stream" - only swap the container.
The subtitles get burned in to the video stream - PMS decodes the movie, adds the text, encodes it again...
m4v subtitles - if internal, they get overlaid by aTV, so PMS transcoder doesn't need to do anything.
Option: wait a bit longer, I am working to implement a subtitle renderer...
I would like to know how you get subtitles to work with m4v/mp4 files? I can only get the subtitles to work on m4v/mp4 if the transcoder is set to direct play. But then the movie skips. I am also seeing max CPU when using subtitles with mkv files. I am glad to here you have something in the works. Love plexconnect and you have done a great job developing it.
Using synology 1513+
Latest plexconnect 0.3-1
Apple TV 3
Thanks for your help
Jonathan
Sent from my iPhone using Tapatalk
Apple TV 3
Jonathan
Check you have the latest PMS as i believe there are a number of fixes that have gone out related to subs.
Sounds awesome. Not to be unpaintient ;-), but do you think this is ready?
No, I don't think it's ready. Otherwise it would already be publicly available on github... :-D
Hehe. Ment instead.
Sounds awesome. Not to be unpaintient ;-), but WHEN do you think this is ready?
My pms is version 0.9.8.175-88ffbb2. DSM 4.3 The package center on my synology 1513+ says this package is up to date. Is there somewhere I can get the latest version of PMS for synology?
Jonathan
Jonathan
The downloads page ;)
https://plex.tv/downloads
Apple TV 3
Jonathan
This is how I solved it for myself.  I'm running on a DS1512+
https://forums.plex.tv/topic/90361-trying-to-direct-stream-mp4-with-embedded-subtitles/?p=525662
Awesome! Thanks. I’ll get it updated and let you know if it fixes the subtitles on m4v/mp4 files.
