If you read the read before posting thread and post all the information it helps with someone assisting you.
I suspect the issue is with transcribing that specific video file (which is why posting the info would help). What format is the video in the mkv, what format is the audio? Are the subtitles embedded or external? Etc etc.
The difference between the Sammy client and ATV is the formats they play natively.
OK, thank you drewbie.
The subtitles as external. And the data information of one of the problem files is :
Please provide more info in your PMS machine.
If you force transcoding using the desktop client do you get the same issue?
You need to provide the information requested in the sticky, including “High” (note the capital H) logs before anyone can help further.
That log is huge, can you play the movie for 10 seconds and then stop it so it appears in your on deck, stop PlexConnect, delete the log, restart PlexConnect, play the movie without doing anything else, then stop PlexConnect when you get the issue again.
That way only relevant information will be in the log.
f00b4r,
I can recreate something similar - a movie stutters slightly when using subtitles.
We will look into it but bear in mind PlexConnect does not currently have it’s own subtitle renderer and relies on the PMS (not sure if the issue lies there).
Different clients play files differently and as I said before PlexConnect does not currently have it’s own subtitle renderer so non-ATV compatible subs need to have transcoding by the PMS, it might be the 1080p was stressing your original setup too much.
Different clients play files differently and as I said before PlexConnect does not currently have it's own subtitle renderer so non-ATV compatible subs need to have transcoding by the PMS, it might be the 1080p was stressing your original setup too much.
Can MP4 videos get automatically transcoded IF external srt subtitles are selected since otherwise they are not visible because of absence of subs renderer in plex connect? Alternatively, can we have an option for this until renderer gets implemented, please?
I understand that plexconnect does not have its own subtitle renderer, but one thing is not logical, and I repeat: it is what makes the PMS transcoding of subtitles, so should catch him in any situation? because it crashes only when using plexconnect?
